hmotors lists to different types of b16a swaps which ones do you guys buy?
Hmotors lists two swaps
30001 - B16A 88-91 (SiR I) Motor, Tranny, Computer
160Hp 111Trq 10.2 Compression (JDM)
$ 1250.00 Plus shipping and handling.
30002 - B16A 88-91 (SiR I) Complete Change Over
$ 1499.00 Plus shipping and handling.
If you were going to do this swap and you were using say hasport mounts and linkage, and integra 90-93 axles then you wouldnt need the full swap you'd just want the motor, tranny, ecu right?
Enlighten me
Yes this has prob. been said before just help a long time member out.
Enlighten me
IIRC complete changeover means complete. alternator, ac compressor/ps if you have them, axles, intermediate shaft, distributor..all that stuff.
--gabriel
--gabriel
Did you see the parts list of what all is included with each swap package? Hmotors can get you the Hasport mounts, linkage, VTEC subharness and 90-93 Teg hubs and knuckles if you need them.
I Understand.
But it does say that just the engine,tranny,ecu does come with an alternator and such other objects.
I havent called hmotors in like two years, but do they give you a good deal on the mounts and such?
Like can someone give me a rough estimate of what they got from Hmotors when they only purchased the engine/tranny/ecu and when they purchased as said before along with mounts, linkage and subharness??
I dont know Im asking newbie ?'s but im just curious, Id like to do a clean swap and I dont want to leave anything out(granted you will always leave somthing out)
but I DONT want to cut and weld shift linkages, Id like for my axles to slip right in(90-93 axles with dust seals removed) and of course the mounts.....
giff74
May 27, 2004 01:24 AM
