Oil Pressure meter??
Old Nov 26, 2001 | 05:16 PM
IGGY's Avatar
Default Oil Pressure meter??
For those of you who have installed a oil pressure meter how did you do it? Was it an easy task? Am I better off having my dealer or mechanic install one? I ask because I'm thinking about getting one and it is a question that my friend and I have.
Old Nov 26, 2001 | 05:44 PM
Big Phat R's Avatar
Default Re: Oil Pressure meter?? (IGGY)
you're better off with an oil temp gauge IMO.
instructions usually come with the gauge. you have to decide between a mechanical or electrical type.
Old Nov 26, 2001 | 07:14 PM
IGGY's Avatar
Default Re: Oil Pressure meter?? (Big Phat R)
Why temperature and not pressure? Isint pressure more important than temperature?
Old Nov 26, 2001 | 09:23 PM
IGGY's Avatar
*Yawn* It's late I'll see if any of you guys post tomarrow.
Goodnite Everyone! Sweet dreams!
Old Nov 26, 2001 | 09:48 PM
Andrew Sites's Avatar
I would say that you should purchase both. However, IF you only install one, go with the pressure gauge. Unless you are using the car for track use(constant high RPM), or its turbo an oil temp. gauge is not as necessary as an oil pressure gauge.
Old Nov 26, 2001 | 11:21 PM
nfn15037's Avatar
Default Re: Oil Pressure meter?? (Andrew)
Well, actually, if you arent using it for track time, or major boost, you dont really need either. It really draws attention to your car too, which isnt always good.
Old Nov 28, 2001 | 02:14 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
i run both. get the mechanical ones, so friggin simple to instal. well, except maybe the oil temp because of the weld in pan fitting, but aside from that, they are very straightforward and simple to install.
kid-crx
Oct 6, 2005 09:22 PM
DV98CVC
Feb 17, 2003 08:47 PM
