HELP. Axels splines don't match brake rotors
Old Jul 25, 2004 | 07:01 PM
elflacoloco's Avatar
Default HELP. Axels splines don't match brake rotors
We have just about finished up on swapping a B16A1 Y1 Cable Transmission into my son's 91 Civic Hatch. The motors in it runs,idles good, other than a small water and oil leak everything up to this point has been ok. Am trying to install the axels that came with the motor but the spline will not fit into the brake rotors.
The spline seems to be larger than what the brake rotors are. What do we do, can anyone help with this problem? Other than match up the shift linkage, and a few small other items on a punch list, looks like it will be ready to roll soon.
Thanks,
flaco loco
Old Jul 25, 2004 | 07:30 PM
Jester88Si's Avatar
Default Re: HELP. Axels splines don't match brake rotors (elflacoloco)
Is the hatch an STD??? if it is you'll need to use si or dx knuckles
Old Jul 25, 2004 | 07:36 PM
vtecn8ive's Avatar
Default Re: HELP. Axels splines don't match brake rotors (Jester88Si)
Yup Hf/STD/(i think)lx need DX/SI/EX steering knuckles knuckles.
Old Jul 25, 2004 | 08:32 PM
when you say knuckles. what are you referring too. the end of the drive shaft splines.
thanks,
flaco loco
P.S. after the engine warmed up anf the raditor fan came on I got a check engine
light. We did not put the second fan back into the car because we are not using the a/c. could this be why the engine light is on.
Old Jul 25, 2004 | 08:51 PM
eda6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elflacoloco &raquo;</TD></TR><TR><TD CLASS="quote">when you say knuckles. what are you referring too. the end of the drive shaft splines.
thanks,
flaco loco
knucles are what your axles/calipers are mounted on. They connect to upper arm on top on and to the tie rod end and lca on bottom. you need hubs from the 90-93 integra. These will fit your existing knuckles. I think 91 ex knuckles have lager rotor/caliper. Get these if possible.
What code you got?
Old Jul 25, 2004 | 09:27 PM
JapJunkie's Avatar
I have an STD, LOL sounds funny Anyways i ran into the same problem with the axles not fitting the stock knuckles But its cool it just means u get to upgrade ur front brakes,at least i did. I went and got 90-93 DA integra front brakes, easy bolt on and bigger rotors = better stopping I found a pair for $50
Old Jul 26, 2004 | 11:57 PM
is this what I am looking for;
http://cgi.ebay.com/ebaymotors...WA:IT
this says 93 civic si.
can i use this.
thanks,
flacoloco
Old Jul 27, 2004 | 08:39 AM
Blaze45's Avatar
Brrraaaap!
AFAIK you cant use 92-95 hubs. They have got to be from an 88-91 Civic/CRX, hth
Blaze
Old Jul 27, 2004 | 02:35 PM
CRX T-Si's Avatar
Default Re: HELP. Axels splines don't match brake rotors (Blaze45)
the DA ones are the easiest to come by.
Local yard should have them, plus you get bigger brakes.
Old Jul 27, 2004 | 03:05 PM
rioninja's Avatar
You can try seperating the outer cv joint, and reusing the original nubs.
Powered by VTEC
Mar 7, 2008 09:12 AM
b.d.racing
Aug 3, 2006 03:34 PM
psychoblue23
Dec 10, 2005 03:27 PM
N1ghtM0nkey
Jun 14, 2005 09:44 AM
