ABS system comes on even during summer
Old Jul 25, 2004 | 06:39 PM
fab's Avatar
fab
Default ABS system comes on even during summer
My ABS comes on often on snow/icy roads, thanks.
But it is also coming on on dry pavement in the summer when the pavement is not uniform or in good shape. Obviously, this is quite frustrating to have the brake applied by the ABS while you want all the power!
Does anybody has the same problem and if so what can be done to get rid of it?
Old Jul 25, 2004 | 06:46 PM
uncle's Avatar
Default Re: ABS system comes on even during summer (fab)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fab &raquo;</TD></TR><TR><TD CLASS="quote">My ABS comes on often on snow/icy roads, thanks.
Remove the abs.
Old Jul 25, 2004 | 06:51 PM
Hawkze_2.3's Avatar
Default Re: ABS system comes on even during summer (uncle)
Yeah, I gotta go with remove it, too....
Old Jul 25, 2004 | 06:57 PM
vinuneuro's Avatar
Dont remove it completely. Its good in winter. When u start up the car, jst leave the hand brake up one notch and drive a little with it. The ABS light should come on and it is
disengaged.
Old Jul 25, 2004 | 08:36 PM
raylude's Avatar
From: united states of mexico and yes ladies i am, available
Default Re: ABS system comes on even during summer (vinuneuro)
can u just take out the abs fuse when u dont want it to come on then put it in when u do?
Old Jul 26, 2004 | 10:34 AM
bb6h22a's Avatar
That isn't a problem; when the surface become uneven/bumpy, the friction between the surface and the tire changes dramatically. What's happening, is: the tire is losing contact with the road surface, so the clamping force of the brake system overpowers the friction between the surface of the road and the tire = ABS activation.
This also happens if you're applying the brakes, while cresting a hill at high speed; the car gets light, and the friction b/w the tire and surface changes (i.e., is reduced), the brakes overpower the tires and ABS comes on.
This is normal, and should NOT be a reason for you to disconnect ABS.
FACT: you will be quicker around a track with ABS .
FACT: you are safer on the street with ABS .
Point: Keep ABS on your car!
Old Jul 26, 2004 | 06:12 PM
fab's Avatar
fab
Default Re: ABS system comes on even during summer (bb6h22a)
I am a little confused here. I know the theoritical benefits of ABS (especially in winter). This is the first time I have ABS system on my car and it has never caused me much problem not to have it. The roads here are very very bumpy such that it is activated very often. Is it possible that it is too much sensitive on the lude or MY lude?
Old Jul 27, 2004 | 07:03 AM
Daemione's Avatar
Sounds like your suspension is too stiff for the roads in your area.
Old Jul 27, 2004 | 07:32 AM
kablamo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fab &raquo;</TD></TR><TR><TD CLASS="quote">I am a little confused here. I know the theoritical benefits of ABS (especially in winter). This is the first time I have ABS system on my car and it has never caused me much problem not to have it. The roads here are very very bumpy such that it is activated very often. Is it possible that it is too much sensitive on the lude or MY lude?
well the roads in quebec aren't that great in the first place
actually, technically ABS is LEAST efficient and helpful in winter... that is because the point of ABS is to allow you to maintain steering control of the car under braking, it is NOT to reduce braking distance - that is just a common consequence of having ABS.
in winter, your wheels locking causes snow to build up in front of the wheels, helping you stop. in contrast, with ABS, the wheels just slide on the snow, never make traction (to slow the car) on the pavement, so in winter is actually one of the few times ABS isn't as helpful. at least on an unploughed or icy road.
like someone else said, if your suspension is modified and set to be too stiff, it would accentuate more greatly the varying loads on tires as the car goes over bumps, such that the ABS may kick in when it would not normally.
Old Jul 27, 2004 | 07:44 AM
rjr162's Avatar
Default Re: ABS system comes on even during summer (kablamo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kablamo &raquo;</TD></TR><TR><TD CLASS="quote">well the roads in quebec aren't that great in the first place
which is of great importance. It's better for you to maybe slide a little farther forward in the winter... just learn to stop earlier and don't slam the brakes.. no biggy.
Now if you're going around a turn and your tires lock up and you end up sliding over the edge of a hill or something all because you tires are locked up.. now that's pretty shitty. I'd rather have the ABS
Old Jul 27, 2004 | 03:52 PM
fab's Avatar
fab
My suspension is original from the stock car (no mod). I thought that lude owners were tuning their suspension to be even "stiffer". Am I missing something here?
The roads pavement in Quebec really suck.
I still believe that ABS is more safe during winter (except if you are a very good "winter" driver and you outperform the ABS with your driving skill). Even then, someone may not notice icy road conditions sometimes but the ABS will do its job!
For summer, I am still not convinced that ABS is a good thing...
Modified by fab at 5:05 PM 7/27/2004
Old Jul 27, 2004 | 07:05 PM
bb6h22a's Avatar
Default Re: (fab)
Modified by fab at 5:05 PM 7/27/2004</TD></TR></TABLE>
I'm not trying to be rude, but you're wrong. ABS will stop quicker , everytime. It may be the way you're applying the brake pedal; this topic (ABS) has been covered (in depth) - do a search, and peruse the threads (mostly inthe road race forum).
thegeezerkid
Jun 18, 2008 10:24 PM
modulo_s
Aug 10, 2005 05:35 AM
sPaRk'iT
Nov 16, 2004 11:56 PM
Tommy_Gunns
May 20, 2003 11:18 AM
