help with alittle problem
Old Jul 25, 2004 | 06:27 PM
erebunicrx's Avatar
Default help with alittle problem
i have a crx with a ls swap. when i get on it hard at about 6k rpms it cuts out like i hit the rev limiter for a sec and then goes fine. im not sure what it could be. any help would be nice. thanks
Old Jul 25, 2004 | 06:36 PM
crxgator's Avatar
Default Re: help with alittle problem (erebunicrx)
any CEL? last time you did a tune-up?
Old Jul 25, 2004 | 06:39 PM
erebunicrx's Avatar
Default Re: help with alittle problem (crxgator)
no cel but i just did the swap and replaced all but the wires. could it be the wires b/c it only happens around 6k?
Old Jul 25, 2004 | 07:06 PM
DieMaster's Avatar
Needs to be About 20% Cooler
my car does that somes times. It's the fuel pick-up hose on the fuel pump in the tank, It gets some air in it and ofcourse no fuel, no power.
Old Jul 25, 2004 | 07:14 PM
Bee17hatch's Avatar
Default Re: help with alittle problem (JC18)
try replace the wire and see what happen! coz it happened on mine it misfire on high rpm
Old Jul 25, 2004 | 07:37 PM
vtecn8ive's Avatar
Default Re: help with alittle problem (Bee17hatch)
What ECU are you using?
Old Jul 25, 2004 | 09:36 PM
mikerbike's Avatar
Default Re: help with alittle problem (vtecn8ive)
did you repalce your fuel pump? The ls engine is supposed to run from an average of seven psi. That means, if you are using a stock fuel pump, that when you get up into the high rpm it is trying to suck a little more fuel than is available and you will run more and more lean until it just can't run until fuel can build up pressure again. That is what I would try.
Old Jul 26, 2004 | 06:12 AM
crx_88_si's Avatar
Default Re: help with alittle problem (mikerbike)
7 psi? wtf are you smokin? lol
OEM fuel pressure is 28-32psi, when WOT the fuel pressure bumps to 38-42psi.
your oem pump should be fine for a LS motor, aslong as it's not bad. if it worked fine for the previous motor then dont' worry.
Old Jul 26, 2004 | 03:20 PM
mikerbike's Avatar
Default Re: help with alittle problem (crx_88_si)
You are correct. OEM fuel fressure on the CRX is 28-32 psi and 38-42 @ WOT. On the integra however, the OEM fuel pressure is 41-47 psi. I was wrong about thw 7psi thing. I didn't realize the fuel pump bumped up at WOT. I thought it was supposed to be at 38-42 the whole time. Oh well, I was tryng to help a fellow honda tuner, not bash on other people's worthwhile information.
Old Jul 26, 2004 | 06:44 PM
erebunicrx's Avatar
yeah the fuel pump seemed fine with the old motor. i am using a pr4 ecu. this only happens when the car warms up.
Old Jul 29, 2004 | 09:26 AM
mikerbike's Avatar
The fuel pump should seem fine with the old motor. If you read what I wrote, you might have some luck. You went from a 1.5 or 1.6 to a 1.8 liter engine. I wasn't trying to be rude. I have that swap and when I had that problem, I wanted it fixed. I went and did some research. I am not just making suggestions. I am trying to help you from experience. Do what you want.
WheaMyRyceGo
May 31, 2009 04:37 PM
Em1Rookie
Sep 30, 2006 02:16 PM
_jester_
Jan 28, 2005 03:59 AM
Red D Dragon
Apr 3, 2004 06:53 PM
