Cluster swap, no tach for a cluster with tach on a 90 civic hatch std, can i pop out and pop in?
Is it as simple as removing the old one and replacing it with the new one? Any rewiring need to be done? This is on 1990 civic hatch std and the "new" cluster would come from a 90 civic sedan or crx
Needs to be About 20% Cooler
i think it would be a direct replacement. theres even the tach wire you need allredy at the gagues.
wait..so an SI cluster of the same year will bolt up and be DIRECT PLUG IN to an STD? no extra wiring for tach leads or anything?
--gabriel
--gabriel
I swapped a cluster from a 90 crx si. It was all plug and play. All of it, that is, except the odometer. If you don't care about swapping the odometers than it's simple but in my case I had to interchange a few small parts. Other than that just make sure you plug everything in securely and your good to go. Oh yeah, and if you're swapping a cluster from a crx into a hatch make sure you swap the brackets on the cluster too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrquimbie »</TD></TR><TR><TD CLASS="quote"> Oh yeah, and if you're swapping a cluster from a crx into a hatch make sure you swap the brackets on the cluster too.</TD></TR></TABLE>
eh?
--gabriel
eh?
--gabriel
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by almies »</TD></TR><TR><TD CLASS="quote">Is it as simple as removing the old one and replacing it with the new one? Any rewiring need to be done? This is on 1990 civic hatch std and the "new" cluster would come from a 90 civic sedan or crx</TD></TR></TABLE>
would you like to buy my 1.6-VT gauge cluster?
9500rpm tach
155mph Speedo
9500rpm tach
155mph Speedo
StupidSlowRSX
Jan 25, 2007 12:56 PM
Gant
Jul 23, 2004 08:24 PM
CrxSi707
Mar 24, 2003 01:21 PM
