tachs jumping, cars sputtering, car keeps dying please help
Old Jul 25, 2004 | 05:27 PM
LSegHatchy's Avatar
Default tachs jumping, cars sputtering, car keeps dying please help
ok its and 88 si car will start but very hard... it will idle fine for a minute then tach will jusmp and car will sputer and then die also if i give it a lil gas it will flip out and hesitate and the tach will go crazy insane plese someone help i need htis car to work like desperatley
Old Jul 25, 2004 | 05:33 PM
Steemo's Avatar
Default Re: tachs jumping, cars sputtering, car keeps dying please help (Crx2Nermc)
it might be a distributor but im not totally sure on that.
Old Jul 25, 2004 | 05:35 PM
LSegHatchy's Avatar
Default Re: tachs jumping, cars sputtering, car keeps dying please help (Steemo)
thanks hopefully someone with some realy good experiance se this and knows what it might be
Old Jul 25, 2004 | 05:37 PM
Fobtions's Avatar
ignitor
Old Jul 25, 2004 | 05:40 PM
GoFastMotorSports's Avatar
Are you throwing any codes? Most of the times the problems with a boucy tach is the ignitor. I had the same problem,but it turned out my timing was off horribly.
Old Jul 25, 2004 | 05:44 PM
LSegHatchy's Avatar
Default Re: tachs jumping, cars sputtering, car keeps dying please help (GRCCRX911)
dunno check engine light will go on the car will sputter and it will go back off lol this car is insane also how do i check the codes... i have no flippin idea
Old Jul 25, 2004 | 05:45 PM
LSegHatchy's Avatar
oh yeah and its backfiring and poping and pittin and sputtering like its on crack lol
Old Jul 25, 2004 | 05:46 PM
Fobtions's Avatar
lift up the passenger side foot are carpet. you should see a gold plate with a circle window. thats the led that flashes to tell you some diagnostic codes.
Old Jul 25, 2004 | 05:47 PM
Steemo's Avatar
to check codes look at your ecu... when you start up the car it should like blink once or twice or something to acknowledge that it is working and then it will blink a certain number of times and that will tell you what the probelm is just look at the manual to figure out what the code means.
Old Jul 25, 2004 | 05:49 PM
LSegHatchy's Avatar
well unfortuantely i dont have a manual but ill try that brb tell me some other thingws that might help
Old Jul 25, 2004 | 05:56 PM
LSegHatchy's Avatar
ok it blicked once for the start up then after about a minute it blinked twice when the car died thats it that and it was blicking like really fast when i was starteing the car what do you think
Old Jul 25, 2004 | 06:01 PM
ThatRicerDaniel's Avatar
its the coil or ignitor in the dizzy. most likely wont get a code. change the coil. If you take the distributor cap off the coil is the big black one and the ignitor is the small white or brown one.
Old Jul 25, 2004 | 06:04 PM
LSegHatchy's Avatar
Default Re: tachs jumping, cars sputtering, car keeps dying please help (ThatRicerDaniel)
it has an external msd blaster coil and the ignitiong system is virtually new but the ignitor i dunno how do i check if its working properly
Old Jul 25, 2004 | 08:37 PM
3RdT's Avatar
i had that same problem but it turned out 2 be my o2 sensor
Old Jul 25, 2004 | 09:30 PM
mr. carpenter's Avatar
Default Re: tachs jumping, cars sputtering, car keeps dying please help (3RdT)
i think it's the dist.. mine did the exact same thing to me in dallas. bought a new one put it on and had no problems.
Old Jul 25, 2004 | 11:26 PM
EeeJayEight's Avatar
Default Re: tachs jumping, cars sputtering, car keeps dying please help (mr. carpenter)
my autometer tach said that if it was bouncy it was due to a bad ground...so that could be the cause..u might wanna check that out for the tach...the other stuff sounds like a dizzy problem to me
Old Jul 26, 2004 | 02:05 AM
hahagasdcrx's Avatar
Default Re: tachs jumping, cars sputtering, car keeps dying please help (wHiTe91hAtChBaCk)
Check grounds, then check to see if rotor button is screwed down, then test the ignitor.
Sounds like an ignitor problem, rotor button spinning freely, or your crank/cyl sensor is bad. That or your spark plug wires are in the wrong spots.
Old Jul 26, 2004 | 04:21 AM
crx_88_si's Avatar
bouncing tach = ignitor.
decible01
Oct 12, 2006 01:53 PM
JOGADOGGZ
12
Sep 10, 2005 08:21 PM
FalkenSiR
May 7, 2005 09:03 PM
DownRightPinoy
Jul 25, 2003 12:20 PM
accordfan
Oct 30, 2002 11:44 AM
