D16Y8-T won't start after airbags deployed from bottoming out (long story)
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
K, last week I got in technically a "front-end accident" (car bottomed out at 30mph through a section of road that was dug up and replaced with sand, front crossmember is all bent up, search for the thread under my name), so my airbags deployed. My radiator was punctured, but other than that my motor is fine.
I haven't tried to start the car until now. It just cranks but won't turn over and idle.
I've heard that when airbags deploy, they blow out fuses? I'm going to check and see if my fuel pump turns on when I put the key to the on position, be right back.
the fuel pump fuse i believe blows when this happens , or a relay or something , i know somthing shuts off when the airbags deploy , that really sucks man good luck!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hella_JDM »</TD></TR><TR><TD CLASS="quote">the fuel pump fuse i believe blows when this happens , or a relay or something , i know somthing shuts off when the airbags deploy , that really sucks man good luck!</TD></TR></TABLE>
WOOHOO! Right on bro. Replaced the fuel pump fuse and she started right up.
I did not know that the fuel pump fuse and the SRS fuse were one and the same.
Good call Honda!
Good call Honda!
ya most likely a safety mechanism. good luck with the car... lemme know wus up meng.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicRyda2k »</TD></TR><TR><TD CLASS="quote">ya most likely a safety mechanism. good luck with the car... lemme know wus up meng.</TD></TR></TABLE>
ehh, just gotta replace the lower crossmember, radiator, windshield, airbags and re-work the upper radiator support and she'll be back on the streets.
ANNiHiLATORS
May 27, 2011 07:43 PM
bimmeracer
Nov 3, 2008 08:46 PM
