B16A FRONT MOUNT
Old Jul 25, 2004 | 01:48 PM
T--Rex's Avatar
Default B16A FRONT MOUNT
Just installed my b16a into my crx dx, but the front mount on the b16a is about 1.5 inches off of the front mount on the crossmember. My mechanic said he can fabricate one and weld it on for $80 or so... is it really worth it? Do you NEED the front mount. He said i do... just wondered what everyone else does?
Modified by Matrix_Zero at 3:58 PM 7/26/2004
Old Jul 25, 2004 | 01:54 PM
90dxhatch's Avatar
Default Re: B16A FRONT MOUNT (Matrix_Zero)
what mounts are you using? i no one really uses a front mount.
-joe
Old Jul 25, 2004 | 02:23 PM
T--Rex's Avatar
Default Re: B16A FRONT MOUNT (90dxhatch)
i am just looking at the stock b16a front tranny mount. My stock dx engine had one and it of course just bolted up. I assumed the b16a front tranny mount would bolt up in the same place as none of the kits came with a front tranny mount. But it doesn't line up the same.
Does anyone else use all 4 motor mounts(d-side p-side, rear tranny mount, and front tranny mount?
Or do you just leave off the front tranny mount?
Old Jul 25, 2004 | 03:15 PM
mrchaos's Avatar
most kits use three mounts
Old Jul 25, 2004 | 03:50 PM
temp's Avatar
Default Re: B16A FRONT MOUNT (mrchaos)
HCP engineering mount kits use 4 mounts LIKE HONDA DESIGNED THE CAR TO USE
Old Jul 25, 2004 | 04:30 PM
Steemo's Avatar
Default Re: B16A FRONT MOUNT (temp)
i dont know what kind of hcp mounts you have but they only come with three. d side p side and rear... no front
Old Jul 25, 2004 | 05:50 PM
T--Rex's Avatar
Default Re: B16A FRONT MOUNT (Steemo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Steemo &raquo;</TD></TR><TR><TD CLASS="quote">i dont know what kind of hcp mounts you have but they only come with three. d side p side and rear... no front</TD></TR></TABLE>
But a b16a does have a front mount and is designed to have one... Any stock crx engine is designed to have a front mount. Many mounting kits omit this mount. And threfore many people do not use one. So i suppose my question is has anyone had asverse effects on not having a front mount?
Old Jul 25, 2004 | 06:25 PM
temp's Avatar
on the new kits the 4th mount is optional smart ***
Old Jul 25, 2004 | 06:26 PM
temp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Matrix_Zero &raquo;</TD></TR><TR><TD CLASS="quote">
http://www.hcpengineering.com
go there the EF18x kit is the one you want you can run it with 3 or spend the extra money and get the 4th, honda designed the CRX chassis w/ 4 mounts stock, why **** with honda's design?
Old Jul 25, 2004 | 07:37 PM
Jester88Si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by temp &raquo;</TD></TR><TR><TD CLASS="quote">
go there the EF18x kit is the one you want you can run it with 3 or spend the extra money and get the 4th, honda designed the CRX chassis w/ 4 mounts stock, why **** with honda's design?</TD></TR></TABLE> 3 mounts is working for me no adverse affects...
Old Jul 25, 2004 | 08:00 PM
temp's Avatar
Default Re: B16A FRONT MOUNT (Jester88Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jester88Si &raquo;</TD></TR><TR><TD CLASS="quote"> 3 mounts is working for me no adverse affects...</TD></TR></TABLE>
no one ever said it wouldnt work.....its a design issue
Old Jul 25, 2004 | 08:03 PM
krazie1's Avatar
BANNED
I am using the PR mounts and got the fourth mount just as a safety issue
with the shifting and power I got u need it
but it also looks stock and nothing missing to me
if u are running stock mounts I high recommend u getting that mount fabed in there
but if it is aftermarket kit u should be coo until u get to upgrading some major performance stuff
2point2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by temp &raquo;</TD></TR><TR><TD CLASS="quote">HCP engineering mount kits use 4 mounts LIKE HONDA DESIGNED THE CAR TO USE </TD></TR></TABLE>
AND HONDA DESIGNED THE CAR TO BE COMFORTABLE FOR THE 'AVERAGE CONSUMER' no one is going to buy a new car that has cockpit vibration - so they used two soft mounts instead of one hard one.
3 mounts with a harder compound is all you need and is perfectly fine.
4 soft (stock) mounts if you are a ***** and drive like a *****
or 4 hard mounts if you are pushing some really crazy power and like to get a massage while you race your race car down the track
The only way i'd use 3 stock mounts is with Energy Suspension inserts..when i had my ZC i chucked the front mount and just used inserts for the rear one. If your running around on 3 stock mounts you'll rip the rear one very quickly (unless you use inserts..)
Look at HASport.. you can't go wrong.
Hope this helps.
Old Jul 25, 2004 | 08:05 PM
temp's Avatar
Default Re: B16A FRONT MOUNT (2point2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2point2 &raquo;</TD></TR><TR><TD CLASS="quote">
Hope this helps.</TD></TR></TABLE>
yes lets **** with honda engineering because you said so...w00 w00
Old Jul 25, 2004 | 09:51 PM
REX VT's Avatar
The 4th mount is there for a reason
Old Jul 25, 2004 | 10:00 PM
Ivan's Avatar
senior gold member
Default Re: (REX VT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by REX VT &raquo;</TD></TR><TR><TD CLASS="quote">The 4th mount is there for a reason</TD></TR></TABLE>
hcp street kit uses just 3 cause it uses a harder compound. for race cars they recommend the race kit that has 4. I've installed 3 street kits and can tell you that the mounts are stiff. I wouldn't see why you would need 4 unless its a race car. and yes honda designed it with four but its for comfort issure since their mounts are soft.
Old Jul 25, 2004 | 10:01 PM
michael O's Avatar
I'm using the hasport kit which comes with 3 mounts. I could care less about a front mount. The car and the engine both feel really solid. Maybe too solid actually...or maybe that's just all the energry suspension bushings + really stiff shocks//springs combined with the hasport mounts. I don't know.
Old Jul 25, 2004 | 11:23 PM
REX VT's Avatar
Default Re: (Ivan)
More is still better , you are just jealous my car came stock with a crossmember for the front B-serie mount hehehe
Old Jul 26, 2004 | 02:14 AM
2point2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by temp &raquo;</TD></TR><TR><TD CLASS="quote">yes lets <U>**** with honda engineering</U> because you said so...w00 w00 </TD></TR></TABLE>
then keep your car stock fool.
Old Jul 26, 2004 | 07:43 AM
91civicDXdude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Quote, originally posted by temp »
honda engineering never intended for a b series engine to be in the USDM CRX/civic 88-91 chassis SMART ***.
Old Jul 26, 2004 | 10:31 AM
temp's Avatar
Default Re: (91civicDXdude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicDXdude &raquo;</TD></TR><TR><TD CLASS="quote">
honda engineering never intended for a b series engine to be in the USDM CRX/civic 88-91 chassis SMART ***.</TD></TR></TABLE>
you are right, they didnt, and guess what if you DO intend on trying to "improve" on a design why not stick with what they started with IE 4 mounts, oh wait thats not necessary....stupid me for thinking honda designed their cars how they did for a reason.....maybe you guys should go work for honda's engineering department
Old Jul 26, 2004 | 10:38 AM
Driven's Avatar
didn't know Honda designed the USDM CRXs to have B-Series engines.
SuperJay's Avatar
Default Re: (temp)
maybe?
Old Jul 26, 2004 | 10:56 AM
Driven's Avatar
Default Re: (temp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by temp &raquo;</TD></TR><TR><TD CLASS="quote">stupid me for thinking honda designed their cars how they did for a reason</TD></TR></TABLE>
hmmm... Honda also designed the CRX with window cranks and lousy theft preventation.
Honda also designed the CRX with lousy AC line routing.
Honda also designed the CRX SI w/ a sunroof as standard equipment... not even an option to have a slick top.
just because honda designed it, doesn't mean it's a SMART design.
Old Jul 26, 2004 | 11:00 AM
Driven's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by temp &raquo;</TD></TR><TR><TD CLASS="quote">yes lets **** with honda engineering because you said so...w00 w00 </TD></TR></TABLE>
never modify your car ever cause it "***** with honda engineering".
You know your brakes? Designed to work with the stock oem wheels and tyres originally provided.
You know your suspension? designed to work with the stock ride height, wheel selection, and tyres.
your driveaxles, designed to function at the specific ride height that was specified by Honda.
Every bolt on the car, designed to be torqued down to specification, including your air box, your valve cover nuts, even your grounding cables.
