My 98' accord shuts off while im driving.
Old Jul 25, 2004 | 01:32 PM
joshrosen16's Avatar
Default My 98' accord shuts off while im driving.
hey. i'm driving a 98 honda accord, 70k miles, i just had the 70k tuneup, changed rotors, spark plugs, oil change and chemical cleansing.. and replaced O2 sensor, passed smog inpection.. etc. whenever i drive, occasionally my car just shuts off... it could be when im slowing down or even while im on the freeway, the car completely shuts off, but i am able to start it up right away any ideas?
thanks for ur help
Old Jul 25, 2004 | 02:29 PM
Mike813's Avatar
Default Re: My 98' accord shuts off while im driving. (joshrosen16)
thats strange as hell...but in my repair manual signs of stalling/engine cut are caused from the following.
1.loose faulty connections at distributor,coil or alternator
2.insufficient fuel reaching injectors
3.vacuum leak at gasket between intake mani and throttle body
4.idle speed incorrect
5.clogged fuel filter/ water in the fuel system
6.faulty emissions system
7.incorrectly gapped plugs
8.faulty wires
9.vacuum leak in the injection system,intake mani, or vacuum hoses
10.valve clearances incorrectly set
Old Jul 25, 2004 | 02:59 PM
IanCT's Avatar
Have the fuel filter and fuel pump pressure checked. Although it sounds like more than just that, it's very weird, indeed!
Good luck!
Old Jul 25, 2004 | 03:08 PM
Chiovnidca's Avatar
Or he can go to the dealer and have them replace the ignition switch under the recall. They cause a stalling problem like described.
Old Jul 25, 2004 | 03:27 PM
bill-71SS's Avatar
BINGO,like the man said,ignition switch recall
Old Jul 25, 2004 | 03:45 PM
react's Avatar
hummm
Old Jul 26, 2004 | 11:35 AM
Default Re: My 98' accord shuts off while im driving. (bill-71SS)
wow. i didn't even hear of the recall thanks so much i WILL take it in
Josh
Old Jul 31, 2004 | 09:34 PM
Default Re: My 98' accord shuts off while im driving. (Chiovnidca)
thanks man!!! the ignition recall fix did it! however damn honda charged me $75 cause they had to take apart my 'after market' alarm and rewire it into the ignition switch what BULL****.
Old Jul 31, 2004 | 10:10 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joshrosen16 &raquo;</TD></TR><TR><TD CLASS="quote">thanks man!!! the ignition recall fix did it! however damn honda charged me $75 cause they had to take apart my 'after market' alarm and rewire it into the ignition switch what BULL****.</TD></TR></TABLE>
We dont charge for that at our shop. We just cut the wires and let the customer worry about hooking them back up. (we get their ok on that first though)
Old Jul 31, 2004 | 11:25 PM
Riceburner247's Avatar
Ignition recalls also exist for the Acura CL in the 97+ models too. That has nothing to do with your problem, but I felt like contributing anyways.
Mexican Bob
Jul 24, 2016 11:07 PM
minorityxunit
Mar 27, 2014 10:24 PM
mpancha
Feb 27, 2007 05:40 AM
Famous2321
Sep 28, 2005 06:57 AM
BK101
Oct 12, 2001 08:54 AM
