can i use crowe stage2 intake cam with stock exhaust cam
Old Jul 25, 2004 | 08:18 AM
crower_h22a's Avatar
Default can i use crowe stage2 intake cam with stock exhaust cam
hi
i have h22a jdm
crower stage 2 exhaust cam broken from 3 day when i Installed in my engien
my setup
str 70mm tb
i/h/e
wiesco 11:8 w ring/ bor 88
vafc
valvetrain intake valve +1mm
crower cam stage 2
coil blastter ss
p&p head
AEM Fuel Rail
p28
thanks
Modified by crower_h22a at 5:35 PM 7/25/2004
Old Jul 27, 2004 | 05:34 AM
MC_HondaRacing's Avatar
Default Re: can i use crowe stage2 intake cam with stock exhaust cam (crower_h22a)
The car would certainly run on it, but how well is to be determined. Most of the power from these cams comes from the intake cam anyway, so you may not notice much of a loss.
Give it a try and let us know.
Old Jul 27, 2004 | 06:36 AM
Default Re: can i use crowe stage2 intake cam with stock exhaust cam (MC_HondaRacing)
ok
i give it a try
and i will know you
thanks
Old Jul 27, 2004 | 12:14 PM
raser5050's Avatar
damn,crower cams much often broken?
Old Jul 28, 2004 | 07:06 AM
Default Re: can i use crowe stage2 intake cam with stock exhaust cam (raser5050)
i just order new crower stg2
Old Jul 28, 2004 | 07:51 AM
98TypeSH's Avatar
so it didnt work then ? Also, i hope you have hondata or something on that p28.
Old Jul 28, 2004 | 07:52 AM
preludedriver99
Guest
Posts: n/a
I just ordered crower stage 2's!!!!
Old Jul 28, 2004 | 07:59 AM
98TypeSH's Avatar
Default Re: can i use crowe stage2 intake cam with stock exhaust cam (preludedriver99)
crower_h22a said his broke, and he was asking if he could run the stock exhaust cam, with a crower stage 2 intake cam. Fantastic that you got some cams, throw a party, but it has absolutely no relevance to this thread.
Also, i predict a shitty running engine.
Old Jul 28, 2004 | 08:18 AM
fastludeh22's Avatar
Default Re: can i use crowe stage2 intake cam with stock exhaust cam (98TypeSH)
you must have cam gears to have it run well.
i did this with my turbo cams. at first it wouldnt make any power. we adjusted my cam gear on the exhaust to get it in sync w/the other and it gained over 20 just like that, and a lot more as we kept on tuning
Old Jul 28, 2004 | 10:07 AM
SKDRCR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crower_h22a &raquo;</TD></TR><TR><TD CLASS="quote">hi
i have h22a jdm
can i use crowe stage2 intake cam with stock exhaust cam</TD></TR></TABLE>
did you torq the cam caps to spec and in sequence?
Old Jul 28, 2004 | 11:02 PM
Default Re: can i use crowe stage2 intake cam with stock exhaust cam (SKDRCR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SKDRCR &raquo;</TD></TR><TR><TD CLASS="quote">
did you torq the cam caps to spec and in sequence?</TD></TR></TABLE>
yes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preludedriver99 &raquo;</TD></TR><TR><TD CLASS="quote">I just ordered crower stage 2's!!!! </TD></TR></TABLE>
thanks preludedriver99
i am not very very good in english but i under stand what you write to me
i wont to know
why the exhaust cam broken?????
and can any bady show me how i Install crower cam in right step in my engine (pic) pls
thanks for every bady
Old Jul 29, 2004 | 06:37 AM
Daboi630's Avatar
Default Re: can i use crowe stage2 intake cam with stock exhaust cam (fastludeh22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastludeh22 &raquo;</TD></TR><TR><TD CLASS="quote">you must have cam gears to have it run well.
i thought the crower cams were made to run at its best with NO cam gear turning.... someone on HT i read that. maybe bc yours was turbo...i dunno
Old Jul 29, 2004 | 06:55 AM
Default Re: can i use crowe stage2 intake cam with stock exhaust cam (Daboi630)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Daboi630 &raquo;</TD></TR><TR><TD CLASS="quote">
i thought the crower cams were made to run at its best with NO cam gear turning.... someone on HT i read that. maybe bc yours was turbo...i dunno </TD></TR></TABLE>
i meant intake being crower and exhaust being stock. i had to advance the stock exhaust a few degrees to get it in sync w/the crower cam.
Old Jul 29, 2004 | 07:01 AM
Daboi630's Avatar
ohhhhhhhh gotcha!
Old Jul 29, 2004 | 02:16 PM
connvict's Avatar
Why doesnt anyone run stage3's?
Old Jul 29, 2004 | 02:50 PM
98TypeSH's Avatar
Default Re: (connvict)
supposed to be horrible on the idle, and for full race purposes. i dunno, anyone know first hand if the idle is all fuct?
Power Rev Racing
10
Sep 29, 2005 09:12 AM
knxtnh22accord
Jan 10, 2005 09:11 PM
skribblah
Sep 13, 2003 07:07 PM
Itz Darave
May 21, 2003 07:52 PM
Death_to_Thieves
Dec 5, 2002 11:00 AM
