92 accord HELP need power
I recently bought a 92 accord and its so weak. i need this car because im too tall to fit in anything smaller 6'7" what can i do to make this a faster daily driver ?
hey i have the same car what i did was cat back ($250) headers($150) intake,and the thing that gave me most power is when i put a 95 accord vtec head and ecu and ran some wire from ecu to vtec silenoid it wasnt that expesive but when i go to the track i hope to do low 16s hi 15s
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91wagon »</TD></TR><TR><TD CLASS="quote">I will have to go with FatJoe on that one, but it all depends on how much power you want and how much you can spend on it.</TD></TR></TABLE>
since there was no budget mentioned... i will change my post.... turbocharged h22a with EVERYTHING aftermarket other than the head itself and the block...eagle rods, endyn pistons, crower cams, cam gears, valvetrain, lovefab header, custom 3 inch exhaust with magnaflow muffler, test pipe, 5 angle P&P, skunk2 intake manifold(mod firewall to make fit), 70 mm TB, (and if i knew anything about turbos, i would go on and on about the turbo setup so heres the best i can give you...) and a HUGE TURBO!!!!!!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22CB7 »</TD></TR><TR><TD CLASS="quote">h22 or nitrous or Both</TD></TR></TABLE>
a 50 shot would be fun and relatively inexpensive....but i guess once you factor in refilling the bottle and the such...turbo/swap might be best. but if you dont want to spend 2gs and just want something that you can play with and forget about if you get board with it...then go with nitrous...in my opinion!
