Oooohhhh My Plans, will it work?
Old Jul 25, 2004 | 04:56 AM
Idiotboy's Avatar
Default Oooohhhh My Plans, will it work?
Heres what Im going to do, I got a 90 DX Hatch. I want to swap a first gen b16 into it this winter and get it ready for next summer. I want to build the motor a bit, new pistons, rods, cams, cam gears, clutch, flywheel, crank, headers. I am wondering if anyone did this swap into one of youf EF's. Is the 1st Gen b16 a direct bolt in?
Old Jul 25, 2004 | 05:15 AM
Idiotboy's Avatar
Ohh yeah, does anyone know what might be wrong, the rear wheels are locked on the DX hatch, how might I fix that. Its not the parking brake.
Old Jul 25, 2004 | 05:33 AM
CrX-To-Tha-Max-v2.0's Avatar
Default Re: (Idiotboy)
you'll need motor mounts. HASPORT makes some good good mounts imho. There's plenty of info on this site about it...just use search.
Old Jul 25, 2004 | 09:06 AM
0554's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Idiotboy &raquo;</TD></TR><TR><TD CLASS="quote">Ohh yeah, does anyone know what might be wrong, the rear wheels are locked on the DX hatch, how might I fix that. Its not the parking brake.</TD></TR></TABLE>
e brake could be sticking maybe. yes you needs wiring, mounts, shift linkage, axles, in other words no its not a direct bolt in.
Old Jul 25, 2004 | 11:28 AM
Dwight Schrute's Avatar
Default Re: (88crex)
yeah my friends ebrake would stick hardcore. his dad messed with it a bit and sprayed white lithium grease on it. it's all good now.
Old Jul 25, 2004 | 12:13 PM
temp's Avatar
Default Re: (drewthomas14)
why would you buy more then 1 header?
Old Jul 25, 2004 | 01:56 PM
90dxhatch's Avatar
Default Re: (temp)
i would look into more info about this swap if i were you.
-joe
MOCrxHf
Jan 15, 2004 04:53 AM
BriansCrx
Sep 18, 2003 02:11 PM
roadawg
13
May 8, 2003 05:44 PM
HybridHatchC1
May 7, 2002 03:26 PM
