Will 225/45-16 have any rubbing problems with neuspeed sport springs?
Old Jul 24, 2004 | 11:34 PM
Ramocheese's Avatar
Default Will 225/45-16 have any rubbing problems with neuspeed sport springs?
I was wondering if I would have any rubbing problems with running a 225/45-16 tire. I have neuspeed sport springs which are a 1.7" front and 1.5" rear drop I believe.
I used to run 215/40-16 Nitto NT450 tires, but I'd like to go with Yokohama AVS ES100's this time around in a 225 wide if I can pull it off without any problems.
The wheels they would go on are 16x7 Rota Grids.
Any input is appreciated
Old Jul 24, 2004 | 11:45 PM
burnout289's Avatar
Default Re: Will 225/45-16 have any rubbing problems with neuspeed sport springs? (Ramocheese)
if you are going with 225 width, then 45 is too much sidewall. 225/40-16. i was thinking about the wider tire also, but my ES100s stick plenty good [215/45-16].
as for rubbing, not sure. but your chances are better if you aren't using a camber kit to push the top edge of the tire back out.
Old Jul 25, 2004 | 12:02 AM
Ramocheese's Avatar
Default Re: Will 225/45-16 have any rubbing problems with neuspeed sport springs? (burnout289)
Right on, I figured 225's would be a bit too much.
I'm going to probably go with a set of 215/45-16 Azenis then
Old Jul 25, 2004 | 08:23 AM
p nut's Avatar
225's will definately rub. Get 215's.
BTW, ES100's don't come in 215's?
Old Jul 25, 2004 | 10:34 AM
AoiGSR's Avatar
25 Year Member
Default Re: (P Nut)
Toyo t1s 225/40/16s work with stock height integras with either GSR/ITR springs. no rubbing even with wheel to wheel turn with 16x7 rims (make sure of the offset though)
-aoib0t, who runs 225/40/16
Old Jul 25, 2004 | 11:24 AM
sinfulDB1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ramocheese &raquo;</TD></TR><TR><TD CLASS="quote">Right on, I figured 225's would be a bit too much.
I'm going to probably go with a set of 215/45-16 Azenis then</TD></TR></TABLE>
i have 215/45-16 azenis on my car.. i love them.. traction is no longer a problem.. but they do rub.. i have tein stechs..
Old Jul 26, 2004 | 06:30 PM
burnout289's Avatar
Default Re: (P Nut)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P Nut &raquo;</TD></TR><TR><TD CLASS="quote">225's will definately rub. Get 215's.
BTW, ES100's don't come in 215's?</TD></TR></TABLE>
oh yeah. typ-o. that's 205/45-16. my bad. i think an integra with 225s would look pretty wicked, but you might have to get custom backspacing? dunno.
GraphiteMW
Mar 31, 2007 09:14 AM
pdiggitydogg
49
May 15, 2004 06:15 PM
JFG Kevin
Jan 14, 2004 12:57 AM
S2KILLA
Jul 10, 2003 09:50 PM
ebelp
Apr 17, 2002 03:37 PM
