what to set fuel regulator at or in between?
No more than 60psi at maximum manifold pressure, and no less than 30psi at idle with vacuum reference connected.
The chipped ECU should have you running pretty rich as is, so I doubt you would need to increase the rail pressure any.
thanks its set at 42 and i have some rare secret manifold **** with a 70 mm throttle body is that to big?? for my set up..
JDM GSR LSD TRANNY >>>HEADER ON ITS WAY... NOT A CHEAP O EITHER..
jeff
jeff
ADNOH_sol
Engine Management and Tuning
Jun 15, 2015 10:40 PM
