1989 Integra LS Suddenly dies
Old Jul 24, 2004 | 08:57 PM
chrisnova's Avatar
Default 1989 Integra LS Suddenly dies
I own a 1989 Integra LS. Recenly while driving the car just suddenly died. Basically it seemed as if the ignition simply stopped. It started a few minutes, but then runs and keeps cutting out on me. My thought was the engine computer or distributor. Any thoughts? Thanks!
Old Jul 24, 2004 | 09:16 PM
xTravBx's Avatar
Default Re: 1989 Integra LS Suddenly dies (chrisnova)
Does it start and run when cold?
Does it only die when its hot out?
If it runs and cuts out, it sounds like fuel...
Could be main fuel relay? (though i dont know about this one the 1st gen tegs)
Fuel pump..
injector problems..
Seems fuel related though.
Old Jul 24, 2004 | 09:26 PM
chrisnova's Avatar
Default Re: 1989 Integra LS Suddenly dies (xTravBx)
I guess it could be fuel, but the way it dies without any sputtering whatsoever would make me think ignition related, but I guess I need to test it for spark when it happens again.
But the problem occurs both hot and cold. I can only go about 1/4 mile before I start having trouble. The car just shuts down totally, without even a sputter. Then a few minutes later it starts. Barely got home tonight. Thanks for the information. I will check those components you mentioned tomorrow. What about fuel filter? WOuld that do that. I had that happen once on a carbuerated car.
Old Jul 24, 2004 | 09:29 PM
chrisnova's Avatar
Forgot to mention in SC where I live it was in the mid 90s when it happened both times. I did drive it at night and it seemed to run well. ARe you alluding to vapor lock?
Old Jul 24, 2004 | 10:21 PM
PhantomSTi's Avatar
I have money on the main relay.. Mine did that same thing.
Old Jul 24, 2004 | 10:29 PM
JDM civic master's Avatar
i had the same problem with my old 89 rs, it was the distributor
Old Jul 25, 2004 | 08:56 PM
chrisnova's Avatar
And the answer is..... Well it turned out it was a corroded secondary winding output from the ignitor module to the distributor cap. I inserted some sanpaper and sanded off the green corrosion on the brass onthe ignotor module and reassembled and it started tight up.
I diagnosed it using a spark tester and found no spark. Then went right tothe distributor to test the primary and secondary output resistances on the ignitor. They tested OK, but then that was when I noticed the corrosion.
ANyway, thanks for the ideas everyone.
money007
Mar 20, 2007 06:22 PM
DAGS-R
Apr 1, 2005 02:59 PM
drone88
May 13, 2004 01:47 PM
SoCal ITR
May 6, 2004 10:27 PM
