Another lame CRX Si Seat Question
Old Jul 24, 2004 | 08:12 PM
jedubz's Avatar
Default Another lame CRX Si Seat Question
I've tried searching, and I almost just want confirmation...
In order to use my 1991 CRX Si Seats in my 1988 CRX Si, I need to swap over the seat and the rail correct? And will the rail fit correctly? I have heard something about certain bolts will certain wont.. Any one who is a guru on the whole seat swapping thing?
Old Jul 24, 2004 | 08:18 PM
Fobtions's Avatar
Default Re: Another lame CRX Si Seat Question (jedubz)
seat rails do not swap out in between the 88's and the 89-91.
you need to use the entire assembly from the 91 seats and custom fit em . this requires some customized holes.
Old Jul 24, 2004 | 08:30 PM
jedubz's Avatar
Default Re: Another lame CRX Si Seat Question (Fobtions)
Do I use the Seat-belt insert thingies from the 91 Seats or the 88 ones attached to the frame? Anyone with pics of the holes you need to drill in the 91 rails?
Old Jul 24, 2004 | 08:42 PM
Fobtions's Avatar
use the frame mounted buckles. one goes straight through the floor. and the rest need to have the holes enlarged.
Old Jul 24, 2004 | 08:58 PM
doublethink's Avatar
you can also use stamped metal, and get the older rails on the newer seats if you want. but its easiest to drill and thread new holes in the car.
Old Jul 25, 2004 | 12:35 PM
jedubz's Avatar
Wait, have the holes enlarged on the CAR or on the Seat Rail? I'm still way confused as to Where I'm drilling, so no one on this entire site has a picture?
Old Jul 28, 2004 | 07:06 PM
jedubz's Avatar
Anyone? And what sort of drill/bit you use to make this whole?
Old Jul 29, 2004 | 05:34 AM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
**** that ****, that will:
1. take too much time
2. Is not as safe.
what u should do is swap the seat pans out from the 88's to the 91's and then u just bolt them back in
keyknow
10
Apr 12, 2009 12:23 AM
FotoGenetix
Apr 26, 2007 01:51 AM
Nisif
Jun 25, 2006 02:24 PM
type Gendy
Jan 6, 2005 03:14 PM
illmeth0d
Apr 13, 2002 04:18 AM
