ZC into DX alxes questions
Old Jul 24, 2004 | 06:18 PM
nasteboyii's Avatar
Default ZC into DX alxes questions
basically i know we can do the teg axles and teg intermediate (with the change of SI hubs),
option 2 is use some stock SI axles (non intermediate shaft setup)
my question is there any way i can use the intermediate shaft that came on the ZC DOHC setup, what alxes would i use (if any) and/or could i just use the stock DX axles
big trouble need to get swap done, not trying to spend alot more money, what is the best/cheapest solutions
THANKS GUYS IN ADVANCED
dan
Old Jul 24, 2004 | 07:54 PM
Garrett's Avatar
Default Re: ZC into DX alxes questions (nasteboyii)
If you want to use the ZC DOHC tranny you couldn't use sotck CIvic 88-91 axles. You have to use the mid shaft
Old Jul 24, 2004 | 10:46 PM
Nerologic's Avatar
the thing that i run and i tell people to run with the ZC trans is to use DX/SI axles with ZC/integ (bseries) inner joints. You just need to adapt the inner joints onto the the DX/si axles any they work like a charm and u dont have to spend 3 weeks looking for the ZC shaft and axles...
Old Jul 25, 2004 | 06:15 AM
nasteboyii's Avatar
any more info out there
so far its the (nerologic answer)
but the dx has a long axel (i dont understand how to get a short shaft (for use with intermediate shaft ) or using the long shaft with a teg inner joint (aka male end to go into trans, were do i get that from, maybe the pass side axle times 2
thanks for the help more would be appreciated
Old Jul 25, 2004 | 03:41 PM
Nerologic's Avatar
when you run MY setup you dont use the intermediet shaft, u just run the axles alone
Old Jul 25, 2004 | 03:52 PM
nasteboyii's Avatar
Default Re: (Nerologic)
ok sounds good easiest i guess, i dont have to shop for anything so thats great, and i can sell intermediate shaft thanks again
dan
Old Jul 25, 2004 | 04:00 PM
phatrick2332's Avatar
You do know that you can run teg axles on dx hubs right? There the same spline as the Si. How do i kno..i just did it on my buddies 88.
Old Jul 26, 2004 | 12:58 AM
Nerologic's Avatar
Default Re: (phatrick2332)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phatrick2332 &raquo;</TD></TR><TR><TD CLASS="quote">You do know that you can run teg axles on dx hubs right? There the same spline as the Si. How do i kno..i just did it on my buddies 88.</TD></TR></TABLE>
i was talking about the inner joints where the axles go into the trans
Old Jul 26, 2004 | 02:00 AM
hahagasdcrx's Avatar
you are both right. You can use teg, si, or dx axles with dx hubs ( same spline count and diameter). But you can use the teg inner joint with dx-si drivers side axle if you dont want to use an intermediate shaft, or use teg axles if using the intermediate shaft.
1phast1
18
Jul 2, 2005 08:11 AM
nomotor
Mar 3, 2005 11:20 AM
hondaqwert
Mar 3, 2004 06:00 AM
Phoenix1
Nov 18, 2003 08:05 PM
tdc
Mar 5, 2002 07:23 PM
