prelude h22 turbo kit
Old Jul 24, 2004 | 05:00 PM
kook911's Avatar
Default prelude h22 turbo kit
I have decided to get rid of the turbo kit. other things in life are more important. the car had too many problems and it is making my baby not run I am selling it as a package. I WILL NOT PART OUT, UNLESS I CAN NOT SELL AS WHOLE. So this is what is for sale. all this is coming off a 99 prelude
Drag High flow 4 into 1 cast iron turbo exhaust manifold
Turbonetics T4/T3 High flow turbocharger assembly
Turbonetics Deltagate Mark II Wastegate (7 PSI Spring) or i have a tial 35mm also
Drag High Flow front mount intercooler w/polished cast aluminum end tanks (has been painted heat coated black)
BLITZ Super Blow Off Valve
Drag mandrel bent high flow chrome plated intercooler pipes
Drag mandrel bent high flow exhaust down pipe
Drag wastegaste dump tube assembly
Drag Blue silicone hose and hose clamps
Drag High pressure/High volume inline fuel pump
Drag Boost dependent FMU fuel regulator
Intake air filter assembly
Map sensor bypass valves
Stainless steel braided oil feed line w/ fittings
Oil return assembly
All nessasary hardware and fittings
All nessassary hose and hose clamps
All nessassary gaskets
also i am putting in the
AC Autotechnic oil pressure gauge and boost gauge
duel gauge pod
greddy e-manage with injector and ignition harness
blitz fatt II turbo timer
jdm sard fuel pressure reg
b&m fuel pressure gauge
synapse engineering missing link
rc engineering 440 injectors with obd II to obd I harness
that is all i can think of right now. but i am selling it all, so all you would have to do is get it tuned and you are ready to go. shoot me some offers but i know what i am looking to get out of it. turbo has less the 500 miles, no shaft play at all. ask me any question you might have.
here are the pics http://www.imagestation.com/al...age=Y
Old Jul 25, 2004 | 11:41 AM
Morhpeous's Avatar
Default Re: prelude h22 turbo kit (kook911)
i will trade you for the following just for the full turbo kit though:
DH-racing Fully ported intake manifold porte matched to RPM serivices throttle body heres the link:
also AEM cold air 3inch type r intake w/ bypass and all sensors, also jdm header.... let me know whats up here are the links i have for stuff for sale since ur gettn out of turbo...
https://honda-tech.com/zerothread?id=935403
https://honda-tech.com/zerothread?id=932507
+ ill throw yah um cash
Modified by Morhpeous at 3:56 PM 7/25/2004
Tinberland21
Northeast (Sales)
17
Apr 7, 2008 08:37 AM
Tinberland21
Apr 6, 2008 06:19 PM
BeaterKiller
Aug 22, 2004 07:06 PM
spectunedphil
Oct 18, 2002 03:24 PM
