Need help seperating tranny
Old Jul 24, 2004 | 03:30 PM
hybrid1990crx's Avatar
Default Need help seperating tranny
Ok, so I'm trying to fix my LS tranny, it has a broken shifter fork. I tried to seperate the gear housing from the bell...if thats what its called, and I got about a inch gap and I can't get it to come any further. I think the tranny may be in gear, would this be causing it to be stuck together? Thanks in advance.
Old Jul 24, 2004 | 03:42 PM
michael O's Avatar
Default Re: Need help seperating tranny (hybrid1990crx)
Theres a snap ring holding onto one of the shafts that you have to press open. Also did you remember to remove the reverse idler gear bolt and the two shift fork bolts I guess you could call them? They're two bolts with springs and ballbearings on the end.
Old Jul 24, 2004 | 04:05 PM
Default Re: Need help seperating tranny (michaelOlson)
ok so can you tell me where they are located?
Old Jul 24, 2004 | 07:17 PM
michael O's Avatar
All three of the bolts are on the sides of the bell housing. The snap ring is located under a 1/2" plug that a 1/2" breaker bar should be able to undo. The plug should be located at the top of the bell housing.
2wheelhunter
Dec 8, 2006 10:15 AM
shutta
Jun 19, 2006 03:18 PM
giooooo
Jul 20, 2002 10:29 AM
S13 slide
Apr 11, 2002 10:54 AM
