power windows and locks for crx
Yea the japanese model crx, chassis code ef8, had power windows and locks....U can come up on a pair of doors or door panels and switch everything over to ur rex(wiring is required), u can try http://hmotorsonline.com for this. Or i have seen a guy do it w/ some little motorized thingy, that turns the crank, and the switch mounts up on the dash where ever there are spacers....
or you could go to the Junk Yard and pull some doors apart from later model honda's/Acura's and fab it up........I'm sure there are some write ups online about wiring??>.........
Did the Sedan CIVIC EX have power windows optional?...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleepercivic90 »</TD></TR><TR><TD CLASS="quote">did honda make a crx with power windows and locks. if so where could i find the parts for this? could i use stuff out of a civic sedan?</TD></TR></TABLE>
Didn't the Canadian special edition model have power windows? Check Ebay. As far as locks just get an alarm with keyless entry. $200 bucks tops and well worth it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeEFv2.0 »</TD></TR><TR><TD CLASS="quote">
Didn't the Canadian special edition model have power windows? Check Ebay. As far as locks just get an alarm with keyless entry. $200 bucks tops and well worth it.</TD></TR></TABLE>
Yes the special editions did come with power windows
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I3ackfire »</TD></TR><TR><TD CLASS="quote">
not all of them though..it was an option.
</TD></TR></TABLE>not all of them though..it was an option.
My 2 cents:
A small number of Canadian CRX's had power windows from factory as an option, both the SI and the Special Edition.
I have yet to see a set of oem doors, Canadian, USDM, or JDM, that actually came with power locks though. Aftermarket lock actuators are dirt cheap and can be hooked up to pretty much any alarm. Thats what i did.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hOnDadiCt »</TD></TR><TR><TD CLASS="quote">Yea the japanese model crx, chassis code ef8, had power windows and locks....U can come up on a pair of doors or door panels and switch everything over to ur rex(wiring is required), u can try http://hmotorsonline.com for this. Or i have seen a guy do it w/ some little motorized thingy, that turns the crank, and the switch mounts up on the dash where ever there are spacers....</TD></TR></TABLE>
What´s up with the JDM craze ? Why not use power windows from a European CRX , that way you don´t have to turn switches upside down to get them on the right side either.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91’ LS-VTEC »</TD></TR><TR><TD CLASS="quote">Yes the made power window for cxr's. I have them on mine rite now.(o'yeah, they wheren't offerd in the US )
That's funny because I went to the Dealer about two months back to purchase a window regulator for my rex, and the man asked me "power windows?" I asked him if CRX's even came with power windows. He said yes, the Si models do.
Are they trying to make my car JDMyo or what?
</TD></TR></TABLE>That's funny because I went to the Dealer about two months back to purchase a window regulator for my rex, and the man asked me "power windows?" I asked him if CRX's even came with power windows. He said yes, the Si models do.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SETI20 »</TD></TR><TR><TD CLASS="quote">JDM huh.....
...saaaay....are those LHD power windows? Oh my, they are! </TD></TR></TABLE>
Yo, I need a switch like that. My JDM windows have the controls on the right side. Could you get me that switch for my CRX??? That is not modified as I can see so that means the master switch is on the left side....the wright side.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16_madman »</TD></TR><TR><TD CLASS="quote">power locks are easy to install, just takes time. I got some jdm swithces for the windows i'd sell, it's just that LHD power window switches on ebay go for waaay too much money.</TD></TR></TABLE>
PM'ed ya.
PM'ed ya.
As far as I can tell from looking around, no CRX's came with power locks, only power windows. However, the USDM Civic EX and LX both came with power locks, and the lock actuators from those screw right onto the CRX's door latch, into holes that are already there... Then all you have to do is wire in the Door lock control module that also came on the EX and LX and viola, factory honda door locks on your CRX. The only problem I've come up with so far is where to put the switch for the locks... I'm leaning towards puting it somewhere on the center console..
As for power windows, you can use the power regulator from an EX or LX and the tracks from the CRX's manual regulater to have bolt in power windows.. The holes are already in the CRX's doors for this, so there is no real fabrication needed. There is a pretty thorough write-up somewhere around here that describes this process... I followed it and it worked great. Now all I have to do is figure out if I want to spend crazy cash on them fancy LHD switches or use something else that won't be quite as cool, but would cost far less..
ive got a set of CDM (canada) P/windows. They were an option only dealer installed part over here. There was a p/locks set up aswell BUT it wasnt honda parts DEALER option only over here.
mr_valentino20032000
Aug 21, 2004 05:28 PM
