how to hook up AF guage????
Old Jul 24, 2004 | 08:53 AM
blackoutt's Avatar
Default how to hook up AF guage????
i need to know which wire to use on a 2000 civic ex automatic.
Old Jul 24, 2004 | 08:55 AM
blackoutt's Avatar
help
Old Jul 24, 2004 | 09:06 AM
Eresuncabron's Avatar
Default Re: (blackoutt)
wrong section... this is the old car section...
Old Jul 24, 2004 | 09:44 AM
Curtis2kul's Avatar
Default Re: (Eresuncabron)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eresuncabron &raquo;</TD></TR><TR><TD CLASS="quote">wrong section... this is the old car section...</TD></TR></TABLE>
HAHA
Old Jul 24, 2004 | 12:41 PM
hatchback_al's Avatar
Default Re: how to hook up AF guage???? (blackoutt)
red wire-power source- if u want to go ghetto, strip the end of the wire a good bit, take out a fuse that gets power only when the car is turned on, and wrap the wire around one tab on it a good bit, then stick it back in its appropriate place in the fuse box
black wire-ground- strip the end of the wire a good bit, find a bolt going into metal nearby, take out the bolt, wrap the wire around the bolt, reinstall the bolt
3rd wire (usually purple)- tap this into the o2 sensor wire, yours is a 2000 so im not sure which wire on the o2 you use, us EFers only have 1 wire o2s
Old Jul 24, 2004 | 01:01 PM
96-EJ6 B18C's Avatar
Default Re: how to hook up AF guage???? (hatchback_al)
If I remember correctly the white wire is the signal wire for the 4 wire o2's but don't take my word for it search and you will find the answer. And please use wire taps and ground loops, no need to make the install look like poo.
Old Jul 24, 2004 | 06:23 PM
Default Re: how to hook up AF guage???? (96-EJ6 B18C)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96-EJ6 B18C &raquo;</TD></TR><TR><TD CLASS="quote">And please use wire taps and ground loops, no need to make the install look like poo. </TD></TR></TABLE>
He's not lying
buzzsawstan
Jun 30, 2004 09:09 PM
DJ_SaNdOz
May 20, 2004 12:14 AM
5STAR3
Jan 22, 2004 03:47 PM
cd5_2NR
Audio / Security / Video
Apr 20, 2003 09:47 PM
XxCIVICxX
20
Apr 17, 2003 11:44 AM
