New header, now check engine light is on...
Theres the question guys. Just installed my header, put o2 sensors back in place. Had a bit aof a problem though getting the down pipe and cat to seal. Got the problem fixed and hooked everything back up. My check engine light comes on now, but i got everything hooked up right. Help me out ppl, do i need to just reset ECU?
Im guessing mabey your O2 sensor is broken or it was installed wrong. But you never know, mabey sonemthing else is wrong that doesnt have to do with any work you just did. w/ the downpipe and cat seal that wont have anything to do with your check engine light.
nobody can really help you figure out the problem until you figure out what code its trowing check this tread out https://honda-tech.com/zerothread?id=682412
djtech
Feb 6, 2003 05:34 PM
KuG
29
Jan 19, 2002 08:36 PM
