DA b16 swap help.
Old Jul 24, 2004 | 04:34 AM
dropt's Avatar
Default DA b16 swap help.
Dropping in a b16 into a DA. Should be easy enough but no. The drivers side axle is too long. I can get it in and drive but the bearings hit the end of the cv end and cause it to clunk everytime a bearing comes around. It is fully compressed when installed. We're Using the original b18 axles and all original b18 mounts. What am I missing here?
Old Jul 25, 2004 | 01:28 PM
oldskool teggy's Avatar
Default Re: DA b16 swap help. (dropt)
dang.. never heard of that problem.. mine fit perfectly.. was the car originally auto? or do you got the axles mixed up? i'd get ahodl of hasport or somethign and ask them. were the axles off a hydro tranny? all bseries cable trannies are roughly the same and can use the same axles. if it works on your stock motor.. it should work on the b16. what tranny u using?
Skunk.Werks
May 30, 2009 04:21 PM
HOODLOVER
Nov 13, 2007 01:59 PM
kino008
Nov 24, 2004 02:42 PM
