[HELP] my delsol SIR wont start.
Old Jul 24, 2004 | 01:31 AM
hjhoknz's Avatar
Default [HELP] my delsol SIR wont start.
everytime when i drive my delsol to normal operation temperature, and stop some mins in BP for some fuel, when restart again, the revs drop to 0 then stop. restart again, it wont start (i can hear the starter, something like cant pump the fuel), after some try, or wait for some more mins, it can start.
but it starts everytime when cold.
very annoy when some cars waiting for fuel behind, and i cant start my car
anyone know what's wrong with it?
Thanks
Modified by hjhoknz at 2:49 AM 7/24/2004
Old Jul 24, 2004 | 01:34 AM
handa's Avatar
Default Re: [HELP] my delsol SIR wont start. (hjhoknz)
sounds like short on fuel maybe. fuel pump or fuel lines?
Old Jul 24, 2004 | 01:44 AM
AzntaggeR's Avatar
TSPeed Factory
Default Re: [HELP] my delsol SIR wont start. (handa)
next time you go somewhere and shut your car off. put the key back in and put it into the on position and you should hear something prime towards the back which is your fuel pump. if you don't hear it then more then likely it's bad.
Old Jul 24, 2004 | 01:52 AM
hjhoknz's Avatar
Default Re: [HELP] my delsol SIR wont start. (AzntaggeR)
Thanks.
yes, i can hear when turn the key to ON.
is it the IACV dirty?
Old Jul 24, 2004 | 01:55 AM
AzntaggeR's Avatar
TSPeed Factory
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hjhoknz &raquo;</TD></TR><TR><TD CLASS="quote">Thanks.
is it the IACV dirty?</TD></TR></TABLE>
i doubt it. if it was your IACV you would probably have idling problems. i guess you could do simple stuff like checking your fuel filter.
Old Jul 24, 2004 | 02:02 AM
hjhoknz's Avatar
ya, i just replaced the fuel filter last week.
but when reach normal operation temperature, and N gear in waitting traffic, the revs drop to around 400~500 sometimes, is it appeared idling problems?
Old Jul 24, 2004 | 03:15 AM
AzntaggeR's Avatar
TSPeed Factory
well that could be it then. have you recently drained out your coolant? it may have air bubbles in the system which will cause your car to idle weird.
Old Jul 24, 2004 | 03:55 AM
Crxlsturbo's Avatar
could be the ignitor in your distributor. Clean the connections on there if they are dirty. I had the same problem when I sold my friend my 1992 GSR. Runs fine and everything. Then when I go to start it after sometime of driving it and shut it off then restart it again it dies. He cleaned the connections on the ignitor and ever since then its been aaaaokay...
Old Jul 24, 2004 | 09:58 PM
hjhoknz's Avatar
Default Re: [HELP] my delsol SIR wont start. (Crxlsturbo)
today, I resoldered the main relay and clean the distributor.
now it is sweet
Thanks everyone.
lif3tak3n
Jun 24, 2014 06:00 AM
cd5jdm96
May 2, 2014 08:12 AM
Champs32
15
Aug 30, 2010 02:17 PM
teg racer 877
Mar 5, 2009 05:40 PM
