Best camber angle/degree for R???
I finally got my camber kit on and i was wondering if there is anything better than stock camber spec..
people with camber kits.. Did you guys put it at stock spec or ex) -1.5 back -1 front? let me know what's good set up. .
i dont mind little of camber wear on tire .. but not too much.
thanks.
thanks.
depends on what your tire is and what you do with your car. For Yokohama 005 you need -3,5° in the front, the Dunlops go with -2,5°, most R-compounds work with -2,0° and for street application on a normal street tire you don`t need to set camber. It comes with lowering naturally..
my car is daily driver for now. and i sometimes take it to track.
so i should just set it at stock spec? anyways what's stock spec ?? hehe
ok so if i put more - than stock would it handle better than stock?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DutchITR1689 »</TD></TR><TR><TD CLASS="quote">For street, stock is the best.</TD></TR></TABLE>
for street, a 1971 pinto could be considered the best too
I have to agree with this although a little more neg camber helps cornering
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jaesung »</TD></TR><TR><TD CLASS="quote">neg one in the front won't do much damage to the tires.</TD></TR></TABLE>
Neither will -2.5º I run -2.5º f -2.0º r, and have no wear issues. It's toe that will have a negative affect on tire wear.
I just got my Omni Power upper control arms installed, set them at -3 front, -1 rear, for autoX. Going to see how it does this weekend. Also got 1\16" toe out in the front, and cornerbalanced, feels great so far.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jaesung »</TD></TR><TR><TD CLASS="quote">have rear at 0 and front camber at -1.</TD></TR></TABLE>
Uh, no.
Uh, no.
