crx hf/b18a1 swap what harness will i need
i have a crx hf im swaping a b18a1. i know i need to use a crx si wiring harness since i have the 91 integra ecu.i heard it plugs right in. my question is which harness would i need the engine harness only or also the dash harness
please, any answers would be very appreciated thanks
Modified by crxb18a1 at 11:45 PM 7/23/2004
I believe that when i did mine i used the whole si harness with no changes or anything- i have the integra ecu..
oh you hafta change one plug on one sensor... i forget which one right now sry
Oh crap.... i had an si... MPFI... and i don't think the HF had that so i duno sry dude
read this post
https://honda-tech.com/zerothread?id=936115
that guy says the wiring is the same
read this post
HF/si is the same wiring. everything should plug in or you might have to extend a couple of plugs. but use your hf wiring harness. I'm doing the same swap myself so I know.
Yes, use the whole harness. I have that swap. The HF uses the EGR system which you just won't plug in. I didn't modify any lengths of wire. There is one sensor on the back of the b18 block, near the no. 1 cylinder, that you will not use. That is how i did mine and i throw no codes and it runs great. Good luck.
Make sure you hammer the frame on the driver side to clear the alternator.
but yeah like everyone else said, use your HF wire harness.
I have almost the same problem here. i have a b18a with s1 tranny axels clutch but no im wondering about the wiring and ecu i belive i have the stock wire harness from the orginal motor (its a 90 crx DX) i belive i have the stock harness and ecu what else do i need? do i need some OBD1 conversion unit or what?
I need help?
I need help?
i have a 91 crx hf with b18a and s1 (b16 cable) tranny. I used crx si wiring harness and 91 integra axles and half shaft.
CRXH22, You will need to do some wiring if you don't already have a multi-point swap. If your engine is Pre-OBD, you can use your car harness and change the engine harness pluss the extra wires for the injector resistor box and two more injectors. You should probably take it to a shop if you can't do the wiring yourself. I used No-name brand mounts and chopped the integra linkage about 2 1/2 inches. I didn't pound in the frame to clear the alternator and it rubs during medium to hard cornering. Good luck.
i was not able to use the hf wiring harness cuz it was messed up some one hacked at it. but i do have an si engine wiring harness i know this harness bolts on to the hf dash harness however i dont now if all the pins are the same????
if any one has any info please im desperate
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxb18a1 »</TD></TR><TR><TD CLASS="quote">i was not able to use the hf wiring harness cuz it was messed up some one hacked at it. but i do have an si engine wiring harness i know this harness bolts on to the hf dash harness however i dont now if all the pins are the same????
if any one has any info please im desperate </TD></TR></TABLE>
the HF engine harness is not the same as the Si harness - it will plug into the chassis harness, but will not work - the wires in the connectors are in different locations and some wires that are in the driver's side connector are in the passenger's side connector on the HF and vice versa
this is comparison of the wire locations for the driver's side connector
thanks would you happen to have the passenger side connector different and how would i go and fix it so it works
thanks i really apreciated
lunalink
11
Feb 26, 2010 12:56 PM
awdlaser1
10
May 10, 2009 01:29 PM
