swapping throttle bodys??
i have 95 cx hatch with stock intake mani and TB.i got a used eg ex/si TB, and wondering if it will bolt straight to my stock IM? the new TB is of course bigger, hense the reason i got, and will the sensors plug up right..thanx guys..
i know for a fact the sensors,coolant lines,and throttle cable pully will work with out any problems..i just dont know if the d16 t/b will bolt to the d15b8 t/b studs..i guess all you have to do is take a 12mm and try it..what do you have to lose? 20 minutes at the most
im not sure if your gonna gain much because the cx motor is designed foe econmy which is why it has the super small t/b..i think the d16z6 one might be to big for the application but its worth a shot
