custom turbo people??
Old Jul 23, 2004 | 05:05 PM
LUDERH22's Avatar
Default custom turbo people??
im looking into piecing together a "kit" but im not sure what to buy first, i dont want to have to buy some thing that i dont need. im only looking to boost 6psi for now till i can save up for a bottom end build...so were should i start?? i have read the hole turbo thread but its a simple question..so what would the wise recomend for the newbee to turbos???
Old Jul 23, 2004 | 05:36 PM
Nikoli's Avatar
Default Re: custom turbo people?? (LUDERH22)
it doesnt matter what you buy first as long as you have everything in the end you cant have one piece without the other
Old Jul 23, 2004 | 05:39 PM
stinger's Avatar
Default Re: custom turbo people?? (Deckedlude)
https://honda-tech.com/zerothread?id=316373
If you honestly read that you should be good to go i think.
Old Jul 23, 2004 | 07:32 PM
LUDERH22's Avatar
Default Re: custom turbo people?? (stinger)
well thanks for the info... but ive read that thread already and it helps but i guess it really doesnt matter what i buy first because i cant use any of it till its complete...
Old Jul 23, 2004 | 08:15 PM
stinger's Avatar
that is correct good luck
Old Jul 23, 2004 | 08:52 PM
Kal's Avatar
Kal
basic components you'll need regardless of raising the boost are:
Piping - 2" or 2.25" is adequate.
FMIC - Something larger if you want to raise the boost later
Engine/Fuel Management - Hondata, AEM EMS, or any reputable standalone will do well.
Turbo - Your choice. Choosing the trim is important - determine the trim by what you plan to use the car for. Daily driving with a smaller trim, of course, and if it's a drag car, a larger trim will be the pick.
Injectors/Fuel Pump - you'll need higher flowing ones if you plan to raise the boost.
Good manifold - the "log" type are ok, but they're are better ones.
Colder step plugs - you'll want to go colder for your plugs.
Well, that's about it. Besides the basic things you'll need to do to maintain your costly investment... changing the oil more frequently than usual (2000 miles usually) and spark plugs about every two oil changes (really dependent on how you drive). Just remember: It's expensive to maintain a car that was never designed to run a turbo on its engine.
Old Jul 24, 2004 | 12:47 AM
LUDERH22's Avatar
Default Re: custom turbo people?? (Kal)
thanks that helped alot more. and maintnace wont be a problem i usually change my oil at 2500 and that is royal purple and spark plugs too but for plugs i only use bosh platinum's so its not that expensive..
Old Jul 24, 2004 | 12:50 AM
Nikoli's Avatar
i wouldnt use platinums if i were you. they get to hot and besides you dont need to change them that often unless you judt like to spend money
Old Jul 24, 2004 | 01:24 AM
typeass's Avatar
On my turbo lude, I just run the rev hard kit.
Old Jul 24, 2004 | 11:19 AM
Green Lude 93's Avatar
i just finished building a custom turbo kit for me a couple weeks ago. heres a list with rounded prices to give you an idea: most of this is ebay prices so this would be the least amount you could be spending for a good setup...
wastegate $200-250
manifold and gasket $500 (for a nice one)
turbo $550 (for the cheap ones)
stainless oil feed line and fittings $50
oil drain tube and fittings $40
oil inlet and outlet flange and gaskets $30
downpipe and flange $300-400
injectors $varies with co.
fuel pump $100
Intercooler $300-400
piping for intercooler $150
BOV $200
fuel management $depends
Tuning around $200-300
couplings $depends
some gauges to keep on top of things
Old Jul 25, 2004 | 08:55 AM
LUDERH22's Avatar
Default Re: custom turbo people?? (Green Lude 93)
this is what i was hopping to get answerd with. Thanks for the help.
Honda2581
May 14, 2013 06:37 AM
60coaly60
Apr 11, 2010 02:20 PM
89CRXProject
Aug 3, 2008 01:36 PM
dohcMONSTER
Feb 27, 2004 02:27 PM
GSR901
Oct 21, 2003 07:38 PM
