92 accord need power HOW?
Old Jul 23, 2004 | 03:51 PM
reez's Avatar
Default 92 accord need power HOW?
i need a true simple beginners way of getting this car up to a quick daily driver
open to any ideas. please only legit info this is my daily driver i need to get to the J O B
thanx
Old Jul 23, 2004 | 05:05 PM
whiteDCfiver's Avatar
Default Re: 92 accord need power HOW? (reez)
I/H/E
Old Jul 23, 2004 | 05:27 PM
StimpyBoy's Avatar
Ter-bow
Honestly, do a compression test first, find out the condition of your motor. Then either go turbo or swap with an H22.
And SEARCH!
Old Jul 25, 2004 | 12:04 PM
reez's Avatar
Default Re: 92 accord need power HOW? (StimpyBoy)
compression fine Now what steps are involved in the swap? how hard? how much$? can you upgrade after that?
Thanks for your help
Old Jul 25, 2004 | 12:22 PM
The_Todd's Avatar
Farts in the shower
All or most of your questions can be answered by searching.
The available swaps are mainly h22....if your compression is good turbo your accord.
Both should cost around 2K and with a FI (forced induction) setup with your current engine is somewhat limited unless adding more to build your engine. A FI setup is good for about 7-8 psi and 215whp and 230wtq on a stock motor w/good compression.
A H22 out of the box will/should get around 170ish to the wheels (mt). With upgrades ranging from supercharger to a turbo setup the possibilities are more expansive due to the base numbers on the h (NTM its dohc). More work will be needed to keep a stable h22 with FI.
Search, there is an endless amount of info on the subject
HondaGuy4Life
May 20, 2007 12:20 PM
bOOsted_D16
Mar 24, 2006 05:23 AM
greenli0n25
Jan 6, 2004 06:07 PM
