91 headlights/corners and dash in an 89?
I think 88-89 headlights are different and the 90-91. I know for a fact that the corner lights are different. A lot of people swap a crx dash into 88-91 hatch. The only thing different is the cluster cover but you can make that work
the only difference between the 88-89 and 90-91 headlights/corners is the mounting brackets... I think.. if you hold the two brackets side by side you will notice the difference.. they are swapable though between the head/corner lights, but I'm not sure if they will bolt up because I never got that far.
I have both and found the mounting for the corners on 91 are on the actual headlight assembly, so maybe if I were to just take the entire lighting assembly and switch it over? Fill me in, And about the dash, since the 91 is rounded gauge cluster cover, will i need to use the 91 cluster also, thanks so far fellas
badass3dr
Oct 17, 2011 08:17 AM
JokerTypeR
Feb 3, 2008 07:35 AM
scdarksol
Dec 18, 2003 09:44 PM
