b18a swap
Old Jul 23, 2004 | 01:46 PM
LS REX
Guest
Posts: n/a
Default b18a swap
i just bought a wrecked 1990 integra RS with a good motor,tranny, and frontend. i about to swap the motor in my 1990 crx si. i know i need motor mounts but i'm not sure if i need axles and shift linkage. can i use the integra axles and shiftlinkage or do i have to buy a set for this swap. thanks for any help you can give me.
Old Jul 23, 2004 | 02:02 PM
EP3_05's Avatar
Default Re: b18a swap (LS REX)
Axles can be used as long as they are in good condition. The shift linkage can be sued as long as you make it shorter by cutting out a small section(I can't remember how long) and rewelding it back together. Or you can buy one of the many aftermarket shift linkages made for ED b series swaps.
Old Jul 23, 2004 | 07:21 PM
Eresuncabron's Avatar
Default Re: b18a swap (91civic)
Are you sure you can use the 90 axels i thought you had to get 89 for the swap...
is 89-90 the same gen? if they are... totally disregard my comment and i'm sorry for wasting your time
Cut and weld the linkage
Tito559
10
Feb 8, 2011 02:29 PM
crx4ever
Jun 12, 2006 09:45 PM
nk2k2
Feb 9, 2006 04:27 PM
billyonaire
Oct 3, 2004 05:51 AM
Spoonedcivic
May 19, 2004 06:19 PM
