need help with SRS light on 02 cord
Old Jul 23, 2004 | 12:12 PM
02accordsir's Avatar
Default need help with SRS light on 02 cord
hey i got a 2002 accord sedan and i put in indiglo's a little while ago however now the damn SRS light wont turn off. I was wondering if any of you guys knew why its on and how to turn it off. (Other than just yankin the bulb out) Thanks
Old Jul 23, 2004 | 01:18 PM
yun_cheezie's Avatar
Default Re: need help with SRS light on 02 cord (02accordsir)
try reseting it first, here's how...
there is a "2-pin YELLOW" service connector located under your drivers side dash on the backside of the fuse box. remove it and have a jumper wire ready...
1. with the ignition turned to the off position jump the yellow connector.
2. turn your ignition switch to the run position (do not try to start the car).
3. your srs lite will come on for about 6 seconds then go off.
4. with in 4 seconds of the lite going off, unjump the connector.
5. in a few seconds the srs lite will come on again.
6. with in 4 seconds of the srs lite coming on again, jump the connector.
7. the srs lite will go off again.
8. with in 4 seconds unjump the connector.
9. if the srs lite flashes "twice" it's reset. if it stays on, there is a problem and must be fixed before it will reset. PM me if you have trouble. i also know how to get the code using this same method, which will lead you to the problem...if any.
Old Jul 23, 2004 | 04:40 PM
Beach Accord's Avatar
Default Re: need help with SRS light on 02 cord (yun_cheezie)
Old Jul 24, 2004 | 07:56 AM
Default Re: need help with SRS light on 02 cord (Beach Accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 02accordsir &raquo;</TD></TR><TR><TD CLASS="quote">hey i got a 2002 accord sedan and i put in indiglo's a little while ago however now the damn SRS light wont turn off. I was wondering if any of you guys knew why its on and how to turn it off. (Other than just yankin the bulb out) Thanks</TD></TR></TABLE>
any luck?
Old Aug 1, 2004 | 11:21 AM
nice, good diy and thanks for the help. saved me a trip to honda.
Old Aug 7, 2004 | 08:25 AM
someone should make this a "sticky" for SRS trouble shooting...if so, i can also add how to make the srs lite flash codes and how to read them.
Old Aug 7, 2004 | 08:46 AM
.bagged's Avatar
Iam7head did, its in the Basic Guide
Old Aug 7, 2004 | 01:38 PM
Default Re: need help with SRS light on 02 cord (bagged93accord)
good deal...thanx
Old Aug 7, 2004 | 02:30 PM
KTeller8's Avatar
i should try that, but normally you might want to see why it came on in the first place
but like i was trying to remove my dash and unplugged the wires
you should be able to just pull the battery and fix it! damm that reset crap
Old Aug 10, 2004 | 02:53 PM
Default Re: need help with SRS light on 02 cord (KTeller8)
just removing the battery cable will not reset the srs lite...also, the srs lite can set intermittent codes like an engine ecu it you didn't know. reset it first, then see if it comes back on. if it does then there is a problem. so that "reset crap" is an accurate form of diagnosing.
Old Aug 10, 2004 | 04:24 PM
iam7head's Avatar
removing battery cable will not reset SRS light like someone said before.
if you reset the code and it pop back out right away, it's a hardcode(check for disconnected circuit, bad srs unit,etc) if it's a soft code then it's a sensor unit problem(most likely)
luis_ej8
Honda Fit
Jan 8, 2024 11:12 AM
ganappagoli
Feb 9, 2010 10:12 AM
99SilverBullet.b45!
Sep 11, 2006 09:11 AM
technine
May 24, 2006 04:17 PM
LSVTEC408
Jan 2, 2003 12:52 AM
