HF & SI Throttle Cable: The Same?
Old Jul 23, 2004 | 12:06 PM
dr_latino999's Avatar
Default HF & SI Throttle Cable: The Same?
I'm on my way to completing my parts list for MPFI swap in my LX sedan, and I have a HF Throttle Cable. There are four different throttle cables available to my knowledge looking at part numbers -
EX - 91241
LX/DX - 86675
SI - 86677
HF - 86676
Is it the same length as the SI throttle cable that way I do not run into any problems dropping it in.
Old Jul 23, 2004 | 12:37 PM
RACINTWEEK's Avatar
Default Re: HF & SI Throttle Cable: The Same? (dr_latino999)
in know for sure the SI will work
im sure the prices cant be too different between hf and Si
Old Jul 23, 2004 | 12:40 PM
Default Re: HF & SI Throttle Cable: The Same? (RACINTWEEK)
I know the SI Cable will work also, and the prices aren't that much different: $3-5 at most. I do have a HF cable in hand and I want to know if it is the same thing as the SI cable; you would think since both cars were MPFI.
Old Jul 23, 2004 | 12:52 PM
RACINTWEEK's Avatar
i would think the length could only be off by a little
because of the bracket on the manifold
only one way to find out
Old Jul 23, 2004 | 01:35 PM
1st-hybrid's Avatar
HF and Si throttle cables are different. I had to swap out my hf cable in favor of an si cable when I did my b-series swap.
Old Jul 23, 2004 | 11:14 PM
Default Re: HF & SI Throttle Cable: The Same? (1st-hybrid)
Damn, thanks for the heads up. Until I can get my paws on a SI one it will be LX messiness for me.
CO_CReX
May 17, 2007 08:08 PM
bipedbear
Jun 29, 2005 09:15 AM
nwrallyciv
Feb 20, 2005 12:22 PM
civic2299
May 7, 2002 05:49 AM
