Here's my suspension set up. What do you think?
Here's the list of things that I'm going to be paying for tonight to start my suspension upgrades. I know I need more stuff to finish it off. What camber kit shoould I get? Bushings? Sway bars?
Here's what I'm getting;
Coilovers:http://www.omnipowerusa.com/Products...l_Coilover.asp
Strut & Tie Bars:http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT
Rear LCA's:http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT
Let me know what you think. Yeah or nay on any of the items listed. And what other things do I need to complete the whole suspension?
so you going for bling? or handling?
if you noticable handling, not just mental;
buy a good set of tires. there are many to chose from. es100 and azenis fairly cheap.
don't spend money on the strut/tie bars and lower control arm until you upgrade your rear sway bar. search type r rear sway bar in this forum, tons of info.
other than that, its your money, and bling it up any way you want.
Bought the full coilover set.
Now I'm thinking of ST sway bars. Front and rear. The package on ebay has all that I need right?
Or should I buy LCA's and 4 strut/tie bars?
Have you bought the tie bars and LCA's yet? Chances are you won't need the LCA's to make your suspension better... unless you bought typeR rear shocks. As far as strut/tie bars... any and all of these are good in my opinion. I noticed a rather large difference with the front upper, and a pretty big difference with the rear upper. I have yet to install my lower ties.
As far as the swaybar package, S/T is a good setup to go with. It is lighter than alot of bars, being 19mm instead of 22mm so it is probably more streetable. Eibach is another good setup, not to mention typeR or comptech. If you want to get a lil more crazy, go with the JDM typeR bars--25mm front and 23mm rear, a very nice setup.
PS-the strut/tie bars and lca's u picked out are cheesy knockoffs, i personally wouldnt invest in either
you'll feel the sway bar more. why spend money on a front/rear swaybar setup like s/t. you al ready have a 22mm or 24mm in the front depending on the mode you have.
http://www.geocities.com/bretq....html
https://honda-tech.com/zerothread?id=677299
https://honda-tech.com/zerothread?id=310008
use the search function, it has a lot of info. try "type sway" and click archieves, tons of threads on this upgrade. OEM and cheap.
http://cgi.ebay.com/ebaymotors...=WDVW
Would something like this fit my ls then? I'm pretty sure it would if the searching that I've done is right.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarkTeg94 »</TD></TR><TR><TD CLASS="quote"> http://cgi.ebay.com/ebaymotors...=WDVW
Would something like this fit my ls then? I'm pretty sure it would if the searching that I've done is right.</TD></TR></TABLE>
that will fit on your ls perfectly. and it already comes with the beaks kit, so that saves some trouble.
if you haven't figured out yet, beaks and bsq kits are brackets that allow you to mount the sway bar with reduced risk of subframe tear out.
Drivefast6969
Nov 25, 2007 08:28 AM
