TDC on Z6 head
Old Jul 23, 2004 | 08:11 AM
rastaracer's Avatar
Default TDC on Z6 head
Sup peeps, Im doin a mini-me swap on a 90 civic HB Si, I have a d16z6 cyl head and was trying to set it at TDC when putting it on the block, I dont have a 92-95 manual, but I was wondering if the 3 Lines on the cam sprocket were for alignment and just line the lines up on the sprocket with the wierd numbers on the side of the head??? I think this is right but I wanted to make sure befor I get things bolted down.
Old Jul 23, 2004 | 08:41 AM
ServiceAdvisor's Avatar
When under the car, looking up @ the bottom of the crank pulley with the 3 lines facing directly at you look at the notch in the cam cover between the crank pulley and the block. There's a notch as long as a penny and about 2 pennys wide. Line the 3 lines in the dead center and that should put you @ TDC. - Darrell
ps - the single line is 16 degree's BTDC I believe.
Old Jul 23, 2004 | 09:45 AM
4drEF's Avatar
Keyboard Humorist
Default Re: (OldSiHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OldSiHatch &raquo;</TD></TR><TR><TD CLASS="quote">When under the car, looking up @ the bottom of the crank pulley with the 3 lines facing directly at you look at the notch in the cam cover between the crank pulley and the block. There's a notch as long as a penny and about 2 pennys wide. Line the 3 lines in the dead center and that should put you @ TDC. - Darrell
ps - the single line is 16 degree's BTDC I believe.</TD></TR></TABLE>
for using the RARE penny meaurement system!!!
Old Jul 25, 2004 | 07:02 AM
rastaracer's Avatar
Default Re: (4drEF)
ok Im a bit lost, I can only set In line "the smaller one at the notch", the other two are horizantal lines that I lined up with the arrows or triangles on the head, also I noticed there are numbers on the side like p22, p??, p38. etc??? whats these for? also I think I got it right cause the letters "TOP" on the cam is right side up.
tuna-can
Jan 15, 2010 03:35 AM
B18CUL8R
Oct 22, 2008 02:51 PM
RTW DC2R
May 23, 2005 10:33 AM
rastaracer
Jul 30, 2004 06:25 AM
Dokta
Aug 15, 2002 10:31 AM
