95 prelude noise on takeoff sounds like tire screeching as if i were spinning them passenger side fr
it almost sounds like i am spinning the tire when i take off but i am definitely not. It soundslike its coming from the front right tire. i think it happens easier if i am making a left turn say from a turn signal off of a high way.
The noise sounds just like tire screeching when you spin um if they screech. Iwill only hear it in first and second lets say im making a left turn. maybe 3rd but i would really have to Get on it and even then not sure if i could hear it with the engineand other noise at a faster speed. any ideas .Thanks alot
I c you have a vtec model so its a 5 speed manuel
sounds like you have a problem with your clutch slipping on your flywheel. My buddy gsr did te same thing when he replaced his clutch and didnt resurface the flywheel.
Did you just replace the clutch?
I have an ACT clutch and jun flywheel both were installed at the same time both were new. I kinda get the feeling its coming from the front tire
I dont think the clutch is slipping
could the axle be moving front to back or something. its only when there is power applied at the very early stages of 1st and second when there is alot of torque on takeoff
I personally dont believe it is in the transmission or there is a problem with the transmission but i welcome all the help i can get.
As far as I know when a cv joint goes bad most times the boot rips then the grease comes out then after a little while you hear clicking when you turn. I do not hear clicking just a quick screech or squeal im pretty sure it will happen when i go straight too. but isounds like it is coming from the front passenger side tire
Zeino
Mar 30, 2011 01:36 PM
luder22
Oct 21, 2004 12:59 PM
Ross
31
May 8, 2002 02:04 PM
