b18c1 Bore and Stroke
I am doing a report for an engineering class and I need to know the stock bored and stroke for a b18c1.
I've been searching for about half an hour and I figured someone probably just knew off the top of their heads.
B18C1
DOHC Vtec
Horsepower 170
Displacement 1797cc
Deck height 8.347 in
Bore 3.189 in
stroke 3.433 in
rod length 5.429 in
Compression height of piston 1.181in
Wrist pin outside Diameter in 21mm
cylinder head volume 1.181cc
connecting rod big end width .858 in
connecting rod big end housing bore 48
Rod to stroke ratio 1.58
valve angle 26 degree's
Valve size. Intake 33mm Exhaust 28mm
DOHC Vtec
Horsepower 170
Displacement 1797cc
Bore 3.189 in
stroke 3.433 in
rod length 5.429 in
