JDM 4-1 Header leaking somewhere..........
because i can hear the air leaking out of it eversince i put it on. a screeching sound only when i let off the gas and drive off in 1st.
Why are you running 2 exhaust manifold gaskets?
Have a friend partially cover the exhaust tip to build up pressure and check to see what joint or joints are leaking.
the header was leking alot of air with just one gasket then i put another one on and it quieted down but it still leaks air. i tighten them down with a torque wrench too.
-HONDA-
Dec 22, 2006 10:28 PM
xunkn0vvnx
Mar 27, 2006 05:03 AM
