Apexi V-AFC for ITR
Old Nov 26, 2001 | 06:08 AM
MOTOR R's Avatar
Default Apexi V-AFC for ITR
is the Apexi VAFC do any good for the ITR's?give me some advice.
Old Nov 26, 2001 | 07:09 AM
Back in Black's Avatar
Rather OG
Default Re: Apexi V-AFC for ITR (fuzznuts)
if your R is stock, you wont see any real improvement.
I disagree...you can smooth out your curve which means more linear power. Although the gains wouldn't be huge, I'd imagine you could see a 3-4ish whp increase at peak.
Old Nov 26, 2001 | 07:12 AM
TypeRdude's Avatar
If you have at least at least 2 of the following it will add anywhere between 5-15hp: intake, header, exhaust, cams, supercharger, hi-flow cat, testpipe, higher compression pistons. The VAFC is still on special on our site for $299.99 here: http://www.diabloautosports.com/specials.php Dyno tuning is required for best results.
[Modified by TypeRdude, 4:13 PM 11/26/2001]
Old Nov 26, 2001 | 07:17 AM
Rather OG
btw, 3-4 whp = crap...its not an improvement! You'd get more bang for your dollar taking that 300 and getting higher lift cams!!!
Is that all you read? Did you notice...LINEAR POWER?
BTW, what f'in cams do you buy for $300? Wal-Mart or Target?
DV- who enjoys arguing with wetodds who are only concerned with the peak number
[Modified by Darth VadeR, 12:29 PM 11/26/2001]
Old Nov 26, 2001 | 07:39 AM
naturalvx's Avatar
Default Re: Apexi V-AFC for ITR (MOTOR R)
Hit me up
http://www.titanmotorsports.com
go to the group buy section and we are offering it for 300 shipped.
Old Nov 26, 2001 | 08:37 AM
TypeRdude's Avatar
Default Re: Apexi V-AFC for ITR (naturalvx)
shipping is $6 anywhere in the US, in stock. for the $6 shipping just put in your comment box on our order page that you are honda-tech member and shipping will be $6. This is our everyday price, not a groupbuy :D
Old Nov 26, 2001 | 10:42 AM
Toda Party's Avatar
Default Re: Apexi V-AFC for ITR (TypeRdude)
Here's something I was wondering...off of the Hondata site:
The VTEC changeover point can be set anywhere within reason. The Hondata method of setting the VTEC point is better than any other piggyback computer. Why? Hondas have two fuel and two ignition maps (***see the tech section****). With add on VTEC controllers, the camshaft is forced to switch while running on the wrong fueling and ignition tables. This can cause fuel to be as far as 10% out and ignition to be retarded up to 6 degrees. Some VTEC controllers allow a coarse correction for fuelling, none allow correction for ignition advance. The best method is to switch the maps at the same time the camshaft is changed. This is how Hondata modified ecus function.
comments?
Old Nov 26, 2001 | 10:56 AM
sackdz's Avatar
Default Re: Apexi V-AFC for ITR (Toda Party)
comments?
Is this just reffering to the split second the cams change before the maps switch on a stock ECU? Seems like it's not that big of a deal. Sorry if I'm ig'nant.
Old Nov 26, 2001 | 10:59 AM
Toda Party's Avatar
Default Re: Apexi V-AFC for ITR (sackdz)
not sure...they make it sound like it takes 5 minutes for the maps to change or something
Old Nov 26, 2001 | 11:20 AM
naturalvx's Avatar
It's just a groupbuy that has lasted for about a year and a half now, that's our normal price.
Old Nov 26, 2001 | 12:39 PM
Xerzex's Avatar
New User
How long does shipping usually take from either of these companies? I was planning on getting one after a few more mods, but I may as well buy it now.
Question about the VAFC. I posted before that since I've reset my ECU I feel less power from 5-6k rpms. Could I make the proper adjustments with this to correct this problem?
Old Nov 26, 2001 | 12:58 PM
TypeRdude's Avatar
Default Re: Apexi V-AFC for ITR (Xerzex)
shipping would be faster from titan if you are in florida, we are on the west coast
Old Nov 26, 2001 | 01:48 PM
aklucsarits's Avatar
New User
Try a search maybe?...
https://honda-tech.com/zerothread?id=91691
This guy made some nice numbers with a V-AFC on an otherwise stock ITR. +5-7HP from 7500rpm and up...
Andrew
Old Nov 26, 2001 | 02:26 PM
nfn15037's Avatar
Default Re: Apexi V-AFC for ITR (aklucsarits)
Just FYI, Titan motorsports is very good. I had my clutch done there last week and was very impressed with their service and staff. Just my $.02
Caveman74
Nov 27, 2003 01:41 PM
delslow1
11
Mar 27, 2003 08:35 AM
KevinOhlin
Mar 10, 2003 06:06 PM
acs97prelude
Apr 15, 2002 10:17 AM
