Stock ITR dyno results
Old Nov 26, 2001 | 05:48 AM
uncleben's Avatar
Default Stock ITR dyno results
Anyone read this months issue of Sport Compact Car? Their article <U>The Bullshit Filter</U> talks about how car companies misrepresent HP ratings a lot (well duh). They talk about the new SE-R Spec V a lot, 180hp dyno'd at 141whp, ouch.
But anyway, the guy writing the article (Dave Coleman, who appearently has a 97/98 Type R) writes:
"... Take the 1994 to 2001 Integra GSR, for example. Rated at 170 hp, GSR's regularly dyno at 150 hp at the wheels. The 1997 and '98 Type R, which was rated 25 hp higher at 195 hp, regularly registers around 161 hp -- only 11 hp higher."
Have any of you Type R owners (and GSR for that matter) seen these kind of results first hand?
[edit] (i only assume the author, Dave Coleman has an R, cause I've always noticed they show his picture in the mag, smiling next to one)
[Modified by uncleben, 8:49 AM 11/26/2001]
Old Nov 26, 2001 | 06:00 AM
Back in Black's Avatar
Rather OG
Default Re: Stock ITR dyno results (uncleben)
My pos R dynoed at a mere 159 whp stock. Then again, the timing was set at 14 degrees from the factory, amongst other things...
I'm at 184whp now as she's reacted pretty well to the mods.
Old Nov 26, 2001 | 06:11 AM
BITeR's Avatar
New User
Default Re: Stock ITR dyno results (Darth VadeR)
What should factory settings be? Is this a common problem? Maybe we should all check our timing settings.
Old Nov 26, 2001 | 06:18 AM
Rather OG
Default Re: Stock ITR dyno results (BITeR)
I believe it should be set at 16 from the factory...
Old Nov 26, 2001 | 06:48 AM
Apex i ITR's Avatar
From: Toronto, Canada currently residing in ATL, GA, USA
I dyno'd @ 175 with BS mods and the car not running right. Hopefully after Jack touches the car it'll be closer to 180-185
Old Nov 26, 2001 | 06:51 AM
Rather OG
Default Re: Stock ITR dyno results (Apex i ITR)
Is that a C5 or a JDM B18C?
Old Nov 26, 2001 | 06:55 AM
Apex i ITR's Avatar
JDM B18C (Spec R). Found out my intake is to small. Exhaust is holding me back, having ignition issues. But since that dyno I put on a DC JDM header and have been running a re-chipped P-28 ECU.
Old Nov 26, 2001 | 07:00 AM
Rather OG
I figured it had to be a C to have dynoed at that number...
Good luck on the issues
Old Nov 26, 2001 | 07:03 AM
Dirty GS-R's Avatar
New User
I think it's pretty rare for a GSR to dyno at 150whp. The average I've seen is around 140whp bone stock. I know every car is different but I don't think 150 for a stock GSR is very common.
Old Nov 26, 2001 | 07:51 AM
uncleben's Avatar
Default Re: Stock ITR dyno results (2K1 GS-R)
140whp huh? Anyone else?
What about stock LS (B18B1?)
Old Nov 26, 2001 | 08:12 AM
magic hat #9's Avatar
i've seen so many stock 00-01 itr's dyno at ~168whp that i think the average for these cars really is higher than the oft quoted 160whp.
Old Nov 26, 2001 | 08:19 AM
99ITR_SC's Avatar
Default Re: Stock ITR dyno results (monkey_truckR)
GSRs usually dyno at about 140whp, and most ITR are someowhere in the range of 165whp. I think that article is a little off... they probably dynoed one weak R, and used that as a comparison.
Old Nov 26, 2001 | 11:01 AM
uncleben's Avatar
Default Re: Stock ITR dyno results (99ITR_SC)
Well that makes me feel better while i shop for an ITR.
Old Nov 26, 2001 | 11:37 AM
tampaSi's Avatar
New User
Yea i havent ever seen a GSR dyno at 150 stock either. I saw one dyno at 132 stock but i hope that was an exception. Jeez, even my Si managed 145 stock.
Old Nov 26, 2001 | 11:39 AM
pleiades nutz's Avatar
I ran my R on the dyno about two weeks ago, and pulled 169.7 whp w/ AEM CAI. Don't exactly know torque, but was approx. 121.
Old Nov 26, 2001 | 11:55 AM
credditt's Avatar
Default Re: Stock ITR dyno results (nighthawkR618)
I've seen GSRs dyno anywhere from 132 to 150. In 1996/1997 Sport Compact Car had a GSR that and if I remember correctly they said that it put down 159 to the ground stock. I think that they said it did 176 with I/H/E. I could be remembering my numbers incorrectly, but I'm pretty damn sure of this.
BTW: this was the same GSR that they compared against the first ITR they tested in 1997. I think July or August 97 issue. It was the red one with the kaminari body kit and wing, and the 17 inch TSW wheels. It had a DC 4-2-1 header, DC exhaust, and DC DAC intake if I remember right.
[Modified by credditt, 12:58 PM 11/26/2001]
Old Nov 26, 2001 | 12:01 PM
99ITR_SC's Avatar
Default Re: Stock ITR dyno results (credditt)
Don't believe magazine tests! Their dynos are "calibrated" with endorsments if you know what I'm saying
Old Nov 26, 2001 | 12:03 PM
typer_801's Avatar
I'm right there with ya. I believe the 00-up ITR's are a little stronger, but the 97-98's probably dyno around 160 like it was stated. I also heard the OBD-I GSR's tend to dyno higher than the OBD-II. Dunno if there's any truth to that, but just another thing to stir the pot with.
Old Nov 26, 2001 | 12:35 PM
98R #448's Avatar
Default Re: Stock ITR dyno results (typer_801)
Okay so if obdI dyno's higher than the rest. wtf is obd3 going to do? My 98 stock dyno'd at 159hp and 112-114tq. What kind of bs mods can net anyone 24+ hp to the ground. Also why would a 00-01 itr dyno higher than a 97-98 with obd2. Arent these still the same, or did these new colors add 5 or 10 flywheel hp?
Old Nov 26, 2001 | 02:32 PM
uncleben's Avatar
Default Re: Stock ITR dyno results (98R #448)
Heh, I'm curious too... can't different Dyno types effect results to some degree? Dynojet, Dynopak, etc. Can anyone shed some light on this?
Also, what kind of stock whp does a non-vtec 1.8 LS engine usually put down?
Old Nov 26, 2001 | 02:43 PM
Ross's Avatar
25 Year Member
Community Builder
Community Influencer
Active Streak: 30 Days
00's and '01s have a slightly more aggressive cam profile than the 97-98s. I dyno'd my '01 at 172whp w/Comptech Icebox and timing advanced.
Old Nov 26, 2001 | 03:16 PM
JohnnyBoy's Avatar
Default Re: Stock ITR dyno results (Ross1013)
I've been saying that the Type R's here do NOT make 195hp for years now. I put it at more like 185hp or so. How could they say it makes like 2 hp less than the JDM car when that car was so drastically different? Should have sued Honda! LOL! I still love the car though...kinda makes it that much better to be kicking *** with an even less powered car.
Mine dyno'd at 163hp stock
[Modified by JohnnyBoy, 4:17 PM 11/26/2001]
Old Nov 26, 2001 | 06:15 PM
Default Re: Stock ITR dyno results (JohnnyBoy)
I don't know if this is correct or not, but doesn't the LSD eat up alot of that horsepower, thus giving it less hp than we would think at the wheels?
Rockale
11
Oct 5, 2014 08:11 AM
kartman5
Honda Civic (2006 - 2015)
16
Mar 11, 2010 01:59 PM
jstyle
Jul 13, 2003 11:03 AM
turkdog
Jun 24, 2003 07:39 AM
johng
12
Sep 30, 2002 10:06 PM
