1994 jdm gsr complete engine swap with lsd $3200
This is a very clean and complete engine swap which comes with the Engine,5-Speed Limited Slip Differential Transmission,Ecu,Axles,Shift Linkage and Engine Mounts. Will bolt into any 1992-1995 Honda Civic or 1994-2000 Acura Integra. Perfect for high mileage engines that need replacement or if you simply want more power. The engine has approximately 50,000 miles and has zero problems. Comes with Civic Type-R cams, JG adjustable cam gears, b&m fuel pressure regulator, skunk 2 intake manifold, hyperclutch street setup. Runs very strong and has solid compression readings. 220 psi on all 4 cylinders. Has been dynoed at 186 horsepower to the wheels with 131 torque. Gets an average of 30 miles per gallon. If you're interested please drop me an e-mail at "lovemahbootl@yahoo.com" and I will reply promptly. Serious inquiries only. Thank You
TrackSpeedRacing
May 25, 2005 08:51 AM
myhatchrips
Oct 20, 2004 01:10 PM
