Not getting as many miles on a full tank
Old Jul 22, 2004 | 07:29 PM
pbizzlegsr's Avatar
Default Not getting as many miles on a full tank
for some reason im only getting about 250 miles on a full tank of gas..i have a 99 gsr..2 months ago i got about 300..and both with normal driving..vtec once in a while..spark plugs wire dist cap and rotor were changed 4 months ago and fluids were flushed..what could it be..i tried injector cleaner..could it be the fuel filter..since ive owned the car ive never changed that..but i wouldnt think the fuel filter wouldnt have me losing that many miles..i notice everytime i push it, the fuel goes down quickly..itll move 1/8 of a full tank from just drivin 15 miles
Old Jul 22, 2004 | 08:13 PM
IVI's Avatar
IVI
Default Re: Not getting as many miles on a full tank (pbizzlegsr)
it can be fuel filter, air filter, alignment, more weight in the car now aka junk in the trunk.
diffrent type of gasoline your using.. the fuel meter always has the biggest drop after you fill up , the first drop is the largest due to how it is measured.
Old Jul 22, 2004 | 08:26 PM
electronb16si's Avatar
Air filter, Quality of gas, oil change, usually not the case but if the cat is getting clogged it can hurt your gas mileage but would probably hurt it more than you are explaining.
Old Jul 22, 2004 | 08:47 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pbizzlegsr &raquo;</TD></TR><TR><TD CLASS="quote">for some reason im only getting about 250 miles on a full tank of gas..i have a 99 gsr..2 months ago i got about 300..and both with normal driving..vtec once in a while..spark plugs wire dist cap and rotor were changed 4 months ago and fluids were flushed..what could it be..i tried injector cleaner..could it be the fuel filter..since ive owned the car ive never changed that..but i wouldnt think the fuel filter wouldnt have me losing that many miles..i notice everytime i push it, the fuel goes down quickly..itll move 1/8 of a full tank from just drivin 15 miles</TD></TR></TABLE>
dang, i usually get 350-370 or even more miles on about 11 gallons, VTEC almost every day, and mine is a 94 w/ 171K miles on it. Just do a full tune up.
Old Jul 22, 2004 | 08:58 PM
3.504's Avatar
Default Re: Not getting as many miles on a full tank (PatrickGSR94)
i'd say its chokin up. check the air filter
Old Jul 22, 2004 | 09:00 PM
Slain's Avatar
I'm experiencing the same dilemma. I've replaced oem plugs/wires/rotor/cap/fuel filter/o2 sensor/tw sensor still has not cured my problem. Like you I can see the needle go down very quickly even when i'm baby footing it esp from a light. I'm avg 240-250 mpg. Two months ago I was avg 340-360 mpg. When I fill up its still my usual 11 ish gallons. I have a 93 gsr with 185k. Keep me updated if you solve your problem.
Old Jul 22, 2004 | 09:58 PM
integraXTC's Avatar
Default Re: (Slain)
werd. My needle is crazy, I have a heavy foot though, but damn I'm pretty sure my MPGs suck ***. I need a tune up. Hopefully that cures the problem
Old Jul 22, 2004 | 11:55 PM
GSaargh's Avatar
Default Re: (chitwn91rs)
my DA is in the low 200mpg as well,
does anyone know if a very bad clutch can make this happen?
my clutch has about a month left on it. its at a point where it slips very easily, and pretty hard to drive... teh gay, but will get a new clutch soon
Old Jul 23, 2004 | 12:02 AM
NightRiderS2K's Avatar
In-N-Out Burger
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">
dang, i usually get 350-370 or even more miles on about 11 gallons, VTEC almost every day, and mine is a 94 w/ 171K miles on it. Just do a full tune up.</TD></TR></TABLE>
Thats mostly highway miles though right?
Old Jul 23, 2004 | 01:31 AM
alfaaay's Avatar
Default Re: Not getting as many miles on a full tank (NightRider-gsR)
I went from 300 miles on 10 gallons to 250 on 10. I think it has to do with this bootleg intake/filter combo I've gotta run until I can get my K&N filter. You should look into replacing the filter.
Old Jul 23, 2004 | 03:29 AM
PHAT-INTEGRA's Avatar
Let's put it this way I fill up my tank at least 2 - 3 time a week and I have a check engine light that the ECU is throwing a Code P1457 (Fail Emission) from last April that freeken Acura can't get rid of.
Old Jul 23, 2004 | 04:08 AM
Xymox007's Avatar
Default Re: Not getting as many miles on a full tank (alfaaay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alfaaay &raquo;</TD></TR><TR><TD CLASS="quote">I went from 300 miles on 10 gallons to 250 on 10. I think it has to do with this bootleg intake/filter combo I've gotta run until I can get my K&N filter. You should look into replacing the filter.</TD></TR></TABLE>
A new air filter makes a huge difference. I just recently installed a K&N cone filter in place of the stock air filter and I get roughly 325-340 miles off 9-10 gallons. I run the car hard and that mileage includes at least two trips to the triple digit zones (not to mention hard cornering which also impairs fuel economy).
I'd love to get 370 like some of you. You must be driving her on the orange fuel for miles!
Old Jul 23, 2004 | 07:04 AM
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NightRider-gsR &raquo;</TD></TR><TR><TD CLASS="quote">
Thats mostly highway miles though right?</TD></TR></TABLE>
700+ miles/week
My record is 408 miles on a tank, I think it was still took less than 12 gallons to fill up.
My record mpg is 36.x
Old Jul 23, 2004 | 07:35 AM
burnout289's Avatar
damn. i get almost exactly 200 miles/tank but that's mostly city driving. but even all-freeway, i barely get more than 300/tank. my air filter is pretty new, perhaps i should replace the fuel filter like mentioned above?
Old Jul 23, 2004 | 07:40 AM
patdemps's Avatar
Default Re: Not getting as many miles on a full tank (burnout289)
I get around 280 miles per gallon. I've got a turbo GSR running pretty rich. Thats combining street/highway. I think its pretty good considering I love to hit full boost
Old Jul 23, 2004 | 07:45 AM
dFreezy's Avatar
Default Re: Not getting as many miles on a full tank (patdemps)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by patdemps &raquo;</TD></TR><TR><TD CLASS="quote">I get around 280 miles per gallon. </TD></TR></TABLE>
damn, i only get 30 mpg. i'm jealous
Old Jul 23, 2004 | 08:04 AM
sykotic's Avatar
Default Re: Not getting as many miles on a full tank (bl@sterVT)
i get about 350-370 miles per tank... i drive it till the light comes on... I never drive with a/c on, if I even use my a/c its only when i'm sitting somewhere for a long period of time... like waiting on my girlfriend or somethin... its hot here in texas, especially with this black interior =P. Are you guys using your A/C?
Old Jul 23, 2004 | 08:16 AM
Community Builder
Default Re: Not getting as many miles on a full tank (sykotic)
hell yeah I use my A/C, it's not only hot here it's super-humid. I don't use it during my morning commute (low 70's in the morning) or if I'm out late at night unless it's unbearably humid, but in the afternoon and early evening, A/C's gotta be on. I hate it because with my 7.5 lb flywheel, revs drop super-fast between shifts.
Old Jul 23, 2004 | 08:27 AM
In-N-Out Burger
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by patdemps &raquo;</TD></TR><TR><TD CLASS="quote">I get around 280 miles per gallon. I've got a turbo GSR running pretty rich. Thats combining street/highway. I think its pretty good considering I love to hit full boost </TD></TR></TABLE>
280 with a turboed car?? I must drive my car hard then.... I average only 240+ and I fill up to 11 gal most of the time. Dammmmmmn, Im not even turbo.
Yet
Old Jul 24, 2004 | 07:17 AM
EnjoyTheRideDC2's Avatar
Same prob....I swear I think it has to do with quality of gas now a days.....
ruffrhyder
Sep 12, 2008 01:55 PM
dirrtybirdy
Dec 4, 2007 06:09 PM
high23lhatch
Nov 20, 2006 04:29 PM
f22 lx
May 19, 2006 01:19 PM
RacerXintegra2k
Aug 14, 2002 07:24 PM
