Just installed hybrid aem in CRX w/b16 Question about dashpots?
Old Jul 22, 2004 | 06:18 PM
hughesl's Avatar
Default Just installed hybrid aem in CRX w/b16 Question about dashpots?
I just installed the new aem cae specifically for hybrid CRX's.
The intake does not have any vac bungs to run to the dashpots on the manifold.
Since I have a breather filter I just ran them into the location the breather typically would go.
I was thinking about removing the dashpots completly.
Three questions:
1. does anyone know exactly what the purpose of the two dashpots is?
I would like to understand that before I consider removing them.
2. If you remove them how do you plug the holes left in the intake?
3. Anyone that has already removed them, how do you like the results.
Thanks for the help
Old Jul 22, 2004 | 06:31 PM
b16_madman's Avatar
Default Re: Just installed hybrid aem in CRX w/b16 Question about dashpots? (hughesl)
i'm gonna assume you have the xsi swap from the integra, since it came w/the two dashpots on the throttle cable/body etc.
I removed one of the two, and plugged off the other one.
Old Jul 22, 2004 | 06:42 PM
Rywire's Avatar
Default Re: Just installed hybrid aem in CRX w/b16 Question about dashpots? (B16_madman)
I believe all it does is let the rpms fall slower off the throttle. I have had one on, and one off, no noticeable difference.
Modified by droppedcrxsi at 5:12 AM 7/23/2004
hughesl's Avatar
Yeah it is the XSi
Which one did you remove?
Which did you plug?
Any pics.
Thanks
Old Jul 22, 2004 | 08:56 PM
EL Vap133's Avatar
Post pics.
Old Jul 23, 2004 | 10:00 AM
hughesl's Avatar
Default Re: Just installed hybrid aem in CRX w/b16 Question about dashpots? (EL Vap133)
http://www.imagestation.com/al...age=Y
I am working on getting the picture to work.
Install was pretty easy. The directions said you had to open up the hole where the old resonator was, but I did not have to. I was just extra careful when I was sliding the tube in. CAI is touching the strut tower bar, but only at the rubber joint.
Should'nt be a problem.
Old Jul 23, 2004 | 10:09 AM
manson's Avatar
couldn't really get too muc out of this...
point out which ones....
Old Jul 23, 2004 | 10:22 AM
hughesl's Avatar
Default Re: Just installed hybrid aem in CRX w/b16 Question about dashpots? (manson)
Thanks for posting the pic for me.
I will have to take a better pic.
I was posting a pic of the intake because I assumed that was what ELL VAP133 was looking for, but that does not help me with my post question.
One of the dashpots is just above the U in Neuspeed and the other is just above the P.
Hopefully that helps.
Thanks
Old Jul 23, 2004 | 10:26 AM
EL Vap133's Avatar
Looks good! I see what you're talking about, so yours doesn't look like this then right?
Old Jul 23, 2004 | 10:29 AM
hughesl's Avatar
No its got the one labeled #6, but it also has another one next to it.
Old Jul 27, 2004 | 06:07 PM
hughesl's Avatar
It looks like the one dashpot is to keep the throttle from slamming shut and the other is to increase rpm when the a/c comes on. Since I don't have a/c and dont mind engine braking I took both off. I will drive it tomorrow and see if there are any ill affects.
Old Jul 27, 2004 | 08:12 PM
kid-honda's Avatar
I have none of that crap with no problems, as a matter of fact I only have one vaccume line for the FPR and I have no ill effects.
Old Jul 28, 2004 | 05:52 PM
hughesl's Avatar
Default Re: (kid-honda)
Well I drove to work today with the dashpots removed and I did not notice any difference what so ever. I plan to leave them off also.
Old Jul 28, 2004 | 06:05 PM
riceburners1's Avatar
thats a HOT CAI....but why not just get the regular one if ur battery isnt in the way??
Old Jul 29, 2004 | 05:11 PM
hughesl's Avatar
Default Re: (riceburners1)
I got the hybrid intake because:
-It is my understanding that the standard CRX Si CAI is a little small for the B16
-The 99-00 Si is larger in diameter, but I did not want to relocate the battery(it does interfere with that one) so I wasnt sure if it would fit with my goldwing battery. The little battery makes it look like there is tons of space under the hood.
-I was sure the hybrid intake would work and be the correct diameter, since it is for the B16/B18 in the 88-91 CRX
I am pretty happy with the fitment and it sounds good too.
Old Jul 29, 2004 | 06:38 PM
4DRmafia's Avatar
i just took off my dash pot on my d16a6 and started her up she seem fine but i havent drove on the road yet
Old Jul 30, 2004 | 09:54 AM
chattownrexer's Avatar
Default Re: (SkipMic2006)
Hey man where did you order your hybrid intake? I have heard about them but cant find them anywhere! Could you let me know a website or something...
Old Jul 30, 2004 | 10:46 AM
Monty's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceburners1 &raquo;</TD></TR><TR><TD CLASS="quote">thats a HOT CAI....but why not just get the regular one if ur battery isnt in the way??</TD></TR></TABLE>
huh? Looks like a cai to me
Old Jul 30, 2004 | 03:30 PM
hughesl's Avatar
Default Re: (chattownrexer)
http://www.aempower.com/product_intake_app.asp
I got it directly from AEM.
I think the above link will get you there.
Old Jul 30, 2004 | 05:00 PM
CRXBart's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
Remove all that Vacumm hose bulshit. all you need is a Map sensor, a FPR, and your brake booster feed, remove all other garbage including the charcoal canister. Cap off all extra vac outputs in the manifold and t-body. This stuff is not needed, and just adds weight, and more vacumm hose to crack. Yes, I am a weight ****, don't get me started.
Old Jul 30, 2004 | 10:57 PM
QUiKSR20's Avatar
Default Re: Just installed hybrid aem in CRX w/b16 Question about dashpots? (CRXBart)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXBart &raquo;</TD></TR><TR><TD CLASS="quote">
Remove all that Vacumm hose bulshit. all you need is a Map sensor, a FPR, and your brake booster feed, remove all other garbage including the charcoal canister. Cap off all extra vac outputs in the manifold and t-body. This stuff is not needed, and just adds weight, and more vacumm hose to crack. Yes, I am a weight ****, don't get me started. </TD></TR></TABLE>
I got rid of almost all that **** in my crx.. Can you get rid of the purge solonoid too or no? Or can you just have it plugged in with no vacum lines?
i dont care about emmisions just need whats needed and nothing extra.
Old Jul 31, 2004 | 01:45 AM
tweakit's Avatar
Default Re: Just installed hybrid aem in CRX w/b16 Question about dashpots? (QUiKSR20)
I wouldnt mind cleaning most of this junk out too, specially the two dashpots if they arent needed (i have the XSi swap also).
i could remove all that junk with no ill effects? including the charcoal canister? i dont have to worry about emissions here in SD, so i would love to have a cleaner engine bay
Old Jul 31, 2004 | 05:24 AM
CRXBart's Avatar
Default Re: Just installed hybrid aem in CRX w/b16 Question about dashpots? (tweakit)
Yep rip that **** out, I haven't tried it on my b-series car yet, but I'm sure it will work. My Z6 powered beater has only a fuel reg, a map sensor, and the brake booster running off of vacumm. Everthing else includng purge valve are gone. On my b-series car I have removed everything except the charcoal canister, it's been over a year since I drove it, and didn't know you could get rid of it back then.
Stefndogg
Jun 3, 2004 06:46 AM
type Gendy
16
Aug 6, 2003 08:02 AM
bottledcrx
Apr 29, 2003 07:11 PM
keck
Apr 19, 2003 02:51 PM
chirp2hrd
Apr 15, 2003 05:24 AM
