Valve Cover Question
Hi guys, im painting my value cover now. but when i unscrew all the bolts(8) and take the oil cap,spark plugs and two hoses off, but i cant take my valve cover off.
it seems hold there very very tight.
any of u guys had the same problem? what i can do?
I am sure that you looked it all over to see if you left any remaining screws. Also, be sure to double-check in the sparkplug housing area for screws.
After you have re-verified that all screws are out, you might try beating the sides of it with a rubber mallet to loosen it up. It should lift right off once it is loose.
thre is little thing comeout from valve cover..driver side..pull it out from there..btw u have carbon fiber trunk?? can u show me some pic of ur car??
Modified by SpoonKillerB at 7:25 PM 7/22/2004
toshiyuki
Apr 21, 2017 08:38 PM
justYncredible
Aug 19, 2013 06:16 PM
wowowee
24
Jul 19, 2005 05:04 PM
