Power FC with Toda Spec B question
got some question for ppl using power FC with toda spec B
is the original power FC setting lean or rich for toda spec B??
also, will hi compression pistons lean out the mixture??
I hate to sound mean...but go find a dyno, as it will take you a while to figure it out...I had to remove massive amounts of fuel down low, and add in quite a bit of fuel up top...but I've tweaked with the maps so much I have no clue where I am from the stock configuration of the PowerFC.
Austin
Austin
