Should i replace my valves and have my valve surface re-done ?
i've been working my combustion chamber, i put the valves in with no springs, and poured some cola into the bowl.. after about 5 mins it started to leak into the runners...
is this normal.. i would guess not.. the surface is full of small pot holes.. and the valves don't look too good as well.. should i replace all the valves.. and get a 3 angel valve job ?
IF YOUR VALVE ARENT CHIPPED OR ANYTHING THEY SHOULD BE FINE , JUST RE-DO YOUR VALVE SEATS AND SEALS AND YOU SHOULD BE FINE !
