what's cooler mostly water or mostly anitfreeze?
Old Jul 22, 2004 | 04:00 PM
model x's Avatar
Default what's cooler mostly water or mostly anitfreeze?
I've always been told that water cools better than antifreeze but on the bottles it says the more antifreeze the higher the boiling point and it says the same on my coolant tester.
Old Jul 22, 2004 | 04:33 PM
R@mon's Avatar
Default Re: what's cooler mostly water or mostly anitfreeze? (model x)
water releases heat faster than coolant, but water boils at a lower temp (212deg F ) then coolant. collant also has additives to prevent rust in the water jackets and passages.
you can run a 60/40 mix of water to collant and still have the rust prevention and higher boiling point but the better cooling of more water
Old Jul 22, 2004 | 04:52 PM
CRX T-Si's Avatar
Default Re: what's cooler mostly water or mostly anitfreeze? (R@mon)
Try the Redline Water wetter
It suppose to help.
Old Jul 23, 2004 | 04:49 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by model x &raquo;</TD></TR><TR><TD CLASS="quote">I've always been told that water cools better than antifreeze but on the bottles it says the more antifreeze the higher the boiling point and it says the same on my coolant tester.</TD></TR></TABLE>For a circulating liquid system like a car, pure water is the best heat-transfer medium. Having a higher or lower boiling point is a completely different question. Specific heat, specific gravity, thermal conductivity, & viscosity all matter.
Your profile says you live 'up north' so what's that??? I suppose you want protection from freezing. No matter where you are you'll want corrosion inhibitors.
Old Jul 23, 2004 | 12:28 PM
model x's Avatar
Default Re: what's cooler mostly water or mostly anitfreeze? (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">For a circulating liquid system like a car, pure water is the best heat-transfer medium. Having a higher or lower boiling point is a completely different question. Specific heat, specific gravity, thermal conductivity, & viscosity all matter.
i'm Canada but the car is stored in the winter so I'm not worried about freezing point.
Old Jul 23, 2004 | 12:56 PM
showtymers619's Avatar
* B A N N E D *
Default Re: what's cooler mostly water or mostly anitfreeze? (CRX T-Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX T-Si &raquo;</TD></TR><TR><TD CLASS="quote">Try the Redline Water wetter
It suppose to help.
water wetter is actaully only to prevent bubbles from creating its like a anti acid pill for your stomach...
if you want the best mixtures .. ive done 70 water 30 coolant.. with a fan switch and thermostate (mugen) .. that keeps my car very cool
Old Jul 23, 2004 | 01:38 PM
HorsepowerFreak's Avatar
Another option is Evans Cooling. http://www.evanscooling.com
Eventually I'm going to retune my car and run this stuff.
Benjamin
AIM -HPFBen
Old Jul 23, 2004 | 04:09 PM
spaceman's Avatar
Default Re: (HorsepowerFreak)
that evanscooling stuff is interesting..i read somwewhere on the site that its for non-water cooling systems(not sure what that means)..so i emailed them well see
nonvtec92
11
Apr 30, 2008 02:45 PM
hondmywrld
May 9, 2007 12:35 AM
Hyaboosta
Jul 21, 2006 05:01 AM
2SlowDC
Oct 1, 2005 08:32 PM
