Anyone using Clifford Responder Remote?
Old Jul 22, 2004 | 03:11 PM
REDTOPAlchemy's Avatar
Default Anyone using Clifford Responder Remote?
I am trying to change the battery in the Responder remote (AAA-right?). Well, the place that installed it tossed my box and instructions so I have no manual. I am trying to get the battery cover open and it won't give up the goods. I don't wanna force it because I dont wanna have to buy a new remote because I snapped this one in two trying to get the battery cover off. Anyone have any suggestions on how this thing opens...short of being shattered?
Old Jul 22, 2004 | 03:19 PM
JiggyKooAndy's Avatar
Default Re: Anyone using Clifford Responder Remote? (REDTOPChemistry)
towards the bottom there's a little edge on the cover. Lift up a little and slide the cover off (downard).
Old Jul 22, 2004 | 03:46 PM
Relic1's Avatar
depends on if you have the RS3 or the RS3.5
on the RS3 there is a cover on the back left hand side, pull slightly towards you and up on the top of the cover and it will slide up.
the RS3.5 is the same only the cover edge is on the bottom and it slides down.
Old Jul 22, 2004 | 05:28 PM
Default Re: Anyone using Clifford Responder Remote? (JiggyKooAndy)
I should have been a bit more clear in my first post. I have a Matrix 3.5x remote. The thumbnail grrove is near the top by the antenna. The is an arrow on the battery lid near the top pointing upwards. So...I pull towards me first then slide the lid upward?
Old Jul 22, 2004 | 06:36 PM
AoiGSR's Avatar
25 Year Member
from http://www.clifford.com
http://www.clifford.com/guides/ogs/909554.pdf
I don't know if this is your model because the one on that .pdf is for the Matrix RS III. There is a section that says how to do it. Unfortunately, it's just words:
"Battery Replacement
Gently pull the end of the battery door away from the top of the remote control then slide the door up to expose the battery and remove the expired battery. Place the new battery into the remote control observing the correct polarity. When power is returned the remote control will light all icons in the LCD and generate all beeper tones once."
-aoib0t, who doesn't know if that helps.
Old Jul 22, 2004 | 06:45 PM
Mr.Fairlady's Avatar
Just changed my Battery Yesterday.
Use your nail and pull up a tad and slide off. SImple.
But we may have a diffrent remote??
Old Jul 22, 2004 | 06:53 PM
Default Re: Anyone using Clifford Responder Remote? (AoiGSR)
Sweet......thanks much!
Old Nov 9, 2004 | 04:38 PM
speedaholic92's Avatar
Default Re: Anyone using Clifford Responder Remote? (REDTOPAlchemy)
sorry to bring this back up, but how long should the battery last in these remotes? iv'e had my alarm new since late september and the battery icon is already at two from the four it was at brand new...do these go through batteries that quick????
Old Nov 9, 2004 | 09:51 PM
BlkITR01's Avatar
Default Re: Anyone using Clifford Responder Remote? (speedaholic92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedaholic92 &raquo;</TD></TR><TR><TD CLASS="quote">sorry to bring this back up, but how long should the battery last in these remotes? iv'e had my alarm new since late september and the battery icon is already at two from the four it was at brand new...do these go through batteries that quick????</TD></TR></TABLE>
Mine lasts about a month...Pager batteries only last about a month, so it's about right.
Old Nov 10, 2004 | 11:04 AM
Default Re: Anyone using Clifford Responder Remote? (BlkITR01)
really, i guess its not that bad since it has all that stuff to display. thanks
Old Nov 10, 2004 | 11:11 AM
i changed the battery just now and it lit up!! how do you get it to light up? the thing was playing a tune too, now thats cool!!!
Old Nov 10, 2004 | 11:25 AM
Mugen Mike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedaholic92 &raquo;</TD></TR><TR><TD CLASS="quote">i changed the battery just now and it lit up!! how do you get it to light up? the thing was playing a tune too, now thats cool!!! </TD></TR></TABLE>
Hold all 4 buttons down at once until it make a long beep. Once it makes the long beep, release the buttons and press the unlock button. To make the remote vibrate instead of beep, use the same procedure, but press the lock button instead.
Old Nov 10, 2004 | 11:33 AM
Default Re: Anyone using Clifford Responder Remote? (Mugen Mike)
thanks a lot man!!! does the battery go out quicker with the light and vibration on?? thanks again I LOVE HONDA TECH!!!!!!!!!!
Old Nov 10, 2004 | 11:44 AM
Mugen Mike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedaholic92 &raquo;</TD></TR><TR><TD CLASS="quote">thanks a lot man!!! does the battery go out quicker with the light and vibration on?? thanks again I LOVE HONDA TECH!!!!!!!!!!</TD></TR></TABLE>
n/p
Battery will definitely not last as long when using the light and/or vibrate. I always keep the light on, but rarely the vibrating alert. I change the battery about once a month.
ryguy2588
Nov 29, 2012 09:36 PM
hybrider
Mar 24, 2002 01:06 PM
