help wiring my amp
battery, to the hole under the battery on firewall, by the pass seat uder the carpet and front kickpanel, then wedged between the back seat and the rear panel, then into the hatch.
Done it on 4 integras, works like a charm ,easy to do, easy to pull out later.
and use a fuse AT THE BATTERY POST.!!!
I ran mine from the battery, through the engine bay, into the hole in the firewall on the driver's side, along the firewall on the inside, down then left side of the passenger's floorboard, and to the amp underneath the passenger's seat.
In my g2 I drilled a hole. It was a little risky but with good planning you can make it work. If you do this, make sure you have some kind of grommet to protect the wire so the metal doesn't cut it.
91hatchproject
Mar 19, 2010 03:01 AM
